Went To Track
Old May 4, 2009 | 05:41 PM
mpracehemi's Avatar
Went To Track
Went the the local 1/8th track and made 2 passes. 1st pass tried launching @ only 2-3psi and tires brokes loose, pedelled it all the way down 11.11 @72mph.
2nd pass just rolled into it and still lost traction. Before each gear change, got traction but as soon as it shifted lost it. 10.00 @ 80mph.
Next time I'll throw on some slicks and make sure I check my settings on the pod. Had the following; sw7, tq4, rp 0 (mp-8 60%), t 2.
It was fun though with the truck for being the 1st time running it. I did think I'd get better traction with the vht though. On the street, never felt the tires slip while playing.
Btw, tires are nitto's terragrap's.
Old May 4, 2009 | 06:12 PM
madhat's Avatar
Administrator/Jarhead
Did you air down your tires first?
I have traction problems, too. I took a pair of street tires (265's) down to 30lbs, and still slipped at the line, but had traction down the track.
Old May 4, 2009 | 06:53 PM
mpracehemi's Avatar
I basically went to the track to run my car, so being that I towed there I didn't really prep the truck properly. Next time out, I'll have an on board air comp./tank and beable to air back up the the rear tires.
It wasn't a planned deal on the truck, a group of us rented the track ( for racecars) and if someone protested on me running my truck, it wouldn't of happened anyway, but quite a few asked if I'd run it since they saw/heard about the twin turbos and other mods. I had. It was kinda warm out and the track was loose.
Old May 4, 2009 | 10:13 PM
RamWheelsBy4's Avatar
With your mods if you can hook it you should be in the 7s in the 1/8th. Of course 4wd would make that a lot easier. LOL
Old May 4, 2009 | 11:32 PM
mpracehemi's Avatar
That's exactly what I was thinking by comparing to others', like you and your mods. I didn't think I'd have the serious traction issues that I had/have, the streets are better, at least I don't feel the skating like I did at the track. The 1st pass I went through the traps at 85mph according to the speedo, got my slip and read 72mph so the tires wire smoking through the traps hahaha.
I wish I bought a 4x4 at this point, but at the time I bought this truck, I really got it to tow with. I was on a mopar forum and saw this forum on the side ads. I discovered what I could do to a diesel through here. POWER city here I come!!!
With what I've done to this truck, I love the way it handles even at high speeds, it's like it's on rails. It just woke me up yesterday on the traction issues that I have. I'll find a way to get it to hook with help from here. I'll be buying slicks/wheels for starters and fabbing up trac. bars.
Old May 5, 2009 | 12:36 AM
03RAMBUNCTIOUS's Avatar
I watch wind blow...
[QUOTE=mpracehemi;2471174]
QUOTE]
I am in a similar boat, when I finish school, single cab 4x4 here I come
Old May 5, 2009 | 12:55 AM
Slicks, traction bars and a lot of practice to find that optimum launch. Still be a great tow truck just a little time swapping tires at the track. You should have me by 50-75hp easy and maybe more, so with a 1.7s 60' you could be low, low 12s 1/4. Of course if you did that then you have to go for the 11s. LOL
Old May 5, 2009 | 01:23 AM
mpracehemi's Avatar
Yeah, it's a never ending quest to go faster each time out. I was hoping for cool weather on yesterday's track time. According to a friends weather station, we were around 1800ft elevation. I was off with my car by almost half a tenth from my norm., well from what I usually run, but I did some small changes and should of run quicker if the weather was good. Talked to others and they were off too.
Shoot, I have a tunnel ram on the shelf waiting to be installed on the hemi (2- 1130 dominators tuned for my set up), I've been working on my truck too much.
One of my friends remembered when I bought my truck and stated what a diff. I had made. He liked it though.
Old May 5, 2009 | 07:29 AM
Whada's Avatar
I had similar experience friday night went the track for first time with my 2wd truck.Only been down a track three times ever ,last time was 15 years ago.I knew I,d have traction issues but I didnt think that bad.My times were
60 ft 3.0
330 ft 7.9
1/8 11.1 @ 81 mph
1/4 15.4 @ 116 mph
If I could just get this thing hooked up !
Old May 5, 2009 | 08:41 AM
mpracehemi's Avatar
here's my 1st; 60ft- 2.71 boost launched @ 2-3 psi
330- 7.50
1/8- 11.11 @ 72.82
2nd 60ft-2.79 off idle rolled into
330 -6.90
1/8 -10.00 @ 79.92
Old May 5, 2009 | 01:42 PM
TexasCTD's Avatar
Did u run in 4x4??
VikingDiesel
Aug 12, 2007 10:10 PM
one54ton
25
Apr 30, 2006 06:39 PM
SjLingenfelter
Competition / Pulls / OffRoad
Mar 13, 2006 08:57 PM
drew03
76
Feb 6, 2006 07:57 AM
Jambbii
Sep 11, 2004 04:00 PM
