Wanna see what a new turbo, high boost, and low FP get's ya?
The problem is volume. You need to go big on the supply side to the pump from the tank. I ran the stock cannister plus the FASS black iron pick up and then I controlled the pressure with a valve on the return line off the pump. I was pushing enough fuel to keep it over 20psi supplying 260% over a stock CP3 with Smarty and TST through Flux 3.3's. Before the dual feeds to the pump I could suck it to nothing. I think two pickups gives a better result than one big one of the same volume. With your little injectors you shouldn't run out of fuel. KS
Madhat
I don't understand why you would spend money on an airdog before you try what most of us are telling you. Shim the return valve. Get that pressure up to 30psi at idle. If that doesn't solve your problem, you can tell us all "I told you so." If it does solve your problem, you can spend the airdog money on a different mod - on my truck
. But seriously. There are so many guys with the same kit with more fueling than you that are not having any trouble. Every single one is running more pressure than you. I just don't understand why you would argue that and be against trying it.
I set my Walbro to 32 psi and it would suck down to 20-22 psi. If you look at the flow/pressure map on the Walbro, peak flow (volume) occurs around 20psi.
I was over 600hp with it (reliably) before switching to the FASS.
Administrator/Jarhead
I have had this pump to over 30 PSI, and had problems till I set it to 10.
I will switch the filters. If that does not work, I'll try the pressure.
Here's the question... something I asked before when I had problems...
The pump flows at one rate the whole time. The bypass is the only adjustment. So... if the fuel will flow to the least restriction, and there is less than 10psi worth of pressure to push the bypass spring, then that means that the pump is running out fuel, right?
I have more than a gallon of fuel a minute through the pump.
that means that at 10psi the bypass opens there for only letting a small amount of pressurized fuel to cp3. If you turn it up to 20-30psi it takes longer for the bypass to open up there for keeping that much more fuel ready to enter cp3 insead of going back to tank via bypass.
Here's the map of the Flow/Pressure for the Walbros, showing more flow at lower pressure, as ALL pumps of this design will demonstrate.
When you adjust the spring, you're establishing the split between S and R (supply and return), whether that's 20/80, 50/50, 60/40, whatever-- within the limits of the spring.
If you have ANY fuel returning at all from the Walbro's bypass (or whatever it is you are referring to adjusting), then you have plenty of fuel.
You aren't out of fuel until you can't maintain delivery rate the engine wants when you are not bypassing any flow.
I'm not sure what you are talking about in terms of bypass spring (internal to the walbro? external regulator?), but if you make it harder for the fuel to flow to the bypass (via increasing spring pressure), then you will force more fuel to the Supply side by restricting the Return side. Think of it as going from, say, 50S+50R=100 to 70S+30R=100.
Make sense?
Justin
A pressure drop is just plain running out of fuel as it is impossible to push enoug fuel thru the CP-3 inlet unless the pressure is 30 psi or better.
The whole thing gets comlicated further with the aereated fuel causing even more cavitaion in the pump and poor spray patterns from the nozzles.
Pressure, even more than the Walbro can supply, is the only way to approach the limits of a single unmodded CP3. The other choice is duals or a Stage N.
You might be surprised to learn that the "low pressure" supply system that feeds the high pressure pump on some newer HPCR setups is in the triple digits for pressure.
Fleetguard makes a filter for these kinds of system that's tested to over 700psi-- yes a FUEL filter!!
Incidently, the biggest restriction to getting the CP3 to flow enough fuel is internal at the FCA control not the external entry point. A few relatively simple mods on the FCA spool will significantly enhance the stock pumps ability to keep the rail full.
