Walboro install problems
Old Jul 7, 2007 | 08:36 PM
B2hibry's Avatar
I have to say I am frustrated to say the least. Let me first just say I am very mechanically inclined. Now on with the drama.......
Tried installing Walboro 392 kit today and was unsuccessfull. The kit is well thought out and complete but, my pump will not run! I have checked and double checked all connections. I have read the manual atleast 30 times and I can't for the life of me see what is wrong.
1. I have power to the relay in the kit.
2. I do not have power (12v) to the Walboro pump.
3. Pump will run with separate 12v source. Good pump.
4. If I swap connection I can get the factory pump to run although.....
5. No fuel pressure from factory pump, just noise. No fuel in lines.
6. I can't get truck to run at all!!!!
Anyone have a clue as to what is happening or not happening?
Bryan
Old Jul 7, 2007 | 10:16 PM
Benson's Avatar
Bad relay unit? Not sure what else it could be. Good luck.
I sure like mine although I'm the one who got the 391 pump.
Old Jul 7, 2007 | 11:39 PM
Raspy's Avatar
B2,
It sounds like a relay problem.
Separate issue, but, do you have the "in tank" stock pump? I don't see the connection to the stock pump not pumping. How is your new pickup arrainged? I'm curious too, why the 392 instead of the 391. Are you interested in bypassing 10 times the amount of fuel you can burn?
John
Old Jul 7, 2007 | 11:57 PM
jgiachino's Avatar
Originally Posted by Wetspirit
B2,
John
I just ordered from Glacier Diesel....they only have the 392 on their website.....i got the perfromance system....not the competition system....are you saying the 392 is too much?
Old Jul 8, 2007 | 12:46 AM
Luken's Avatar
Give Richard a call tomorrow.
Old Jul 8, 2007 | 08:09 AM
Benson's Avatar
Most guys just want more. The 391's are a little harder to find now I guess. Richard used to have it listed but not any more. Mine gives me all the fuel I'll need. I get a pressure of around 18 or so when the stock was around 7. I'm not after max HP though.
Old Jul 8, 2007 | 09:22 AM
B2hibry's Avatar
LIMITED TIME OFFER: Now, free with every Glacier Diesel Walboro Kit- "Hone Your Electrical Troubleshooting Skills"!!
Well after cooling down overnight and thinking a bit. I wondered if I had something wired backwards. Well, there was something backwards but it was the last thing I suspected. It turns out the Relay Harness from Glacier was wired backwards. Ground/Trigger wire locations were opposite of where they needed to be. This in turn didn't allow the relay to send power to the pump. Swapped wires, I had 15 psi in seconds. What a friggin headache.
Hey Richard, do you test harnesses prior to shipping? Love the kit other than this day and a half fiasco.
Bryan
Old Jul 8, 2007 | 11:21 AM
Luvnacumns's Avatar
How long did it take you without the complications??? I am goona go tear into mine just wondering if I can get it done today???
Old Jul 8, 2007 | 12:10 PM
B2hibry's Avatar
Plan on the day just to be safe. I would venture to say 4-hours minimum. Take your time.
Old Jul 8, 2007 | 12:14 PM
Luvnacumns's Avatar
Thanks!!!!!!!!
Old Jul 8, 2007 | 01:41 PM
RamNu2's Avatar
I just put mine on a couple weeks ago it took me about 2 hours. There is nothing to it really. The long part was dropping the tank and drilling into the tank and ensuring no pieces of plastic tank dropped in. The only problem I have with mine is when it gets below half tank it drops fuel pressure to zero then shots back up. I put a guage on to find out for sure what was happening. Still have to look into it farther though. Good luck with yours.
stock659
Nov 17, 2009 04:15 PM
stock659
Dec 31, 2007 04:37 PM
turbo dreams
May 5, 2006 01:34 PM
Jon_M
18
Apr 24, 2006 04:14 PM
Sea01Cummer
119
Jan 27, 2006 08:38 PM
