Vent Mod havin problems please help!
Im fairly fuel system retarded, how should I go about checking the preassure. Please dont tell me I gotta drop the tank again or anything crazy like that. Also what is the end result of increased system preassure? I never installed a fuel preassure gauge because the idiot that installed mine sold me a gauge that only reads up to 15 psi so I never installed it. I suppose at some point I should address that issue. Possibly when I build my stainless fuel tank.
On a side note is there anyone you have seen that makes an aftermarket fuel gauge for the aux. fuel tank im building. I know Zylstra makes one that is a pretty nice looking digital unit but only if you buy the whole tank and all. I am building a box that holds more fuel, water/meth/both starting batteries and a small storage compartment along with having a hole offset to one side to accomidate the single 6" stainless stack I run. Therefore I dont need their tank. I was just wondering since your in the fuel accessories buisness and all I thought you might have heard of one.
Just cap/plug the broken nipple and return the fuel to a tee into the vent line or filler neck (above the FASS return or you will have a mess).
I would choose the 3/4" vent line....that is also the same place you will drain your aux tank into...
For a sending unit....you can pick up GM style sending unit out of Jegs or Summit that work with a TON of Fuel Level Gauges. Most will define if they work with GM style sending unit....which i believe are the most popular….
Can I assume that you got your rig fixed cquest? Anyway the 3/8 line from the Fass runs into the fuel fillet tee via a metal "y" and I just "t"ed into that line about 2 inchs back of where it comes in. I dont know just normal drivin not gettin on it it seems to run same as always???
I am not up and running yet...
I am not sure what you are telling me about the Fass install...yours sounds right to me. I was just saying...you could abandon the fuel return that you broke...and dump that fuel into the main tank vent line...the 3/4" rubber line that comes off the metal portion of the filler neck.
well its not 100% complete but it will work for now.. still waiting on the pillar pod to finish the writeup. Its a word document..if needed, I can convert to a pdf.
http://rapidshare.com/files/37993612...stall.doc.html
You dont have to sign up..just click next and enter the code provided and you can download the file free. I need a place to really host these write ups
Im downloading it now thanks 8 I'll get it eventually.
I did half of the cp3 mod today (I only modded the fca as I had to go to sears to buy a t30 torx bit so i could get to the gear housing bolts) and changed out my front and back shocks. I couldnt get my cheap camera to take good close-up pics or I wouldve done a write-up on it, probly not as thorough as yours but somethin similar. I do get a slight wide open flutter but I think that maybe becouse I havent yet done the gear part as I said. And I know it cant have anything to do with not being cleaned or sanded well enough as I really took my time. Could also be low fuel as my lights on and I dont know how far I can go now since I just extended the pick-up tube.
Thanks for the good write-up though I will do that as soon as I can get my hands on a gauge to install. No one locally sells them in my small town.
DieselBoy20
Jul 16, 2008 05:25 PM
madhat
61
Mar 19, 2008 09:06 PM
