upper control arm
Old Jan 14, 2006 | 01:55 PM
philobeddo's Avatar
upper control arm
on the upper control arm/passenger side/rear bracket, looks like the bolt will hit exhaust pipe when removed. Has anybody removed the arms without unbolting exhaust? any tricks ?
Old Jan 14, 2006 | 05:22 PM
JbD's Avatar
JbD
I think it's pretty much impossible to get it out without moving the exhaust, unless maybe you push it out against the pipe and cut it. When I did mine I put the bolt in backwards so that I could get it back out without moving the exhaust again.
Old Jan 14, 2006 | 06:17 PM
djgaston's Avatar
I did take it out without removing the exhaust.
What you have to do is undo the two bolts on the side of the engine/transmission that hold the exhaust hanger in place, then I just simply used a floor jack and a 4x4 block to jack up on the pipe slightly in order to get the bolt out.
Once you get it out, you can put the bolt in the other way so you don't have this problem again.
Old Jan 15, 2006 | 09:46 AM
philobeddo's Avatar
thanks guys
searcher
Aug 15, 2006 04:26 PM
winner172
Aug 16, 2004 12:24 PM
Jdonoghue
Jul 27, 2004 10:08 AM
