Updating Smarty Jr.
No sir
This statement is 100% correct. I am running 5.08 and if I have it turned up I can and will slip the tranny. It scared the heck out of me the first time it did it. I couldnt get home fast enough to turn it back down...
smarty version?
Kind of a dumb question. So my smarty has been on the truck level 3 (3 years now I believe)since I bought it and I don't remember what version it is. Do I just plug it back into the truck to power it up and its on the screen display?
Thanks,
Brian
Thanks,
Brian
It's a piece of cake if you are using Win7. All you need is SmartyUSB.exe and the program file. Plug the Smarty into the cumputer and Win7 loads the USB drivers for ya. Open the SmartyUSB.exe and open the program file and off it goes.
After seeing this thread, decided to update and just loaded 10b. Couldn't really tell any difference from 10a, tho. Always looked at it as a sort of fire-and-forget type thing, ran SW1 default 10a for about 5 months, never thought about it. Noticeable improvememnt in power on SW2, default tho. Going to leave it there for now.
Starting to wonder if there's any rationale for going with anything other than the default settings. I realize more power is more power, plain and simple. Just wondering why anybody would tinker with the TQ and timing. Shouldn't MADS have that optimized to the default options? What Smrty Jr. settings do you guys run and why?
The TM settings are there for smoke management. The order of least to most timing is TM1, TM3, TM2, TM4. TM1 is stock, and TM3 is the least smoke of any tuned timing. TM4 is the most timing, and the most smoke, but also the most hp. TM2 is the compromise between smoke and hp, which is why its default.
Around town the increased efficancy of TM4 is lost in the smoke for me.. so its the same mpgs as TM2, just harder on the oil. But on the highway TM4 nets me .5-1ish mpgs more, so if its a LONG drive i'll bump the timing up. Otherwise I run TM2/default all the time.
The TQ settings are there so you can have better accel/tq management than stock, but you can pick how much.. The levels are mild(2), milder(3), mildest(4). I like TQ2 for helping spool the turbo sooner, but if I towed more than 5-7K I may bump it down to TQ3 to help the clutch at low rpms.
Starting to wonder if there's any rationale for going with anything other than the default settings. I realize more power is more power, plain and simple. Just wondering why anybody would tinker with the TM and timing. Shouldn't MADS have that optimized to the default options? What Smrty Jr. settings do you guys run and why?
So default TQ2 is the most agressive, i.e. "least" amount of clutch slip?
I can't imagine how the ECM controls anything in the trans, but the things I don't know would fill volumes...
Yes the most aggressive.. But that means the most clutch/trans slip opportunity.. But that being said the most aggressive on the Jr is the least aggressive on the Sr.
It doesn't control the trans, but it reduces the tq/hp output of the engine until you are above a certain speed, thou I don't recall the speed. For example the AAM 11.5 rear axle is designed for a shock load of 430 ft/lb of tq at the flywheel.. So that is one number I have heard used for the de-rating of our motor until we are at speed. The TQ management on the Smarty removes some of that de-rating, or adds low end tq, which is why it feels so much stronger on the bottom end.
1 Low speed
2 low rpm
3 low boost
4 during gear changes with an auto
OK, got it. I think it just boils down to the manufacturer protecting themselves from stupid drivers. There's always going to be people who will drag race, sled pull, burnouts, whatever. In those cases all bets are off. Get a built tranny or DD clutch.
The design limitations should average out to a factor of two-to-one, safe tolerance, minimum. I suppose it would be better to slip the trans than break an axle trying to floor it from a standstill with a 5-ton trailer behind the truck. Gotta be a weak point somewhere. They are hard to find in the Dodge Cummins. Then again, there's people who can find a way to break an anvil in a sandbox.
