Updateing Smarty Is Pain In The ***
Old Jan 25, 2009 | 10:50 PM
fullthrottle07's Avatar
Ok, I deleted everything from my computer to see if I can start over tonight on a clean slate. I went to the link that Larry provided (basically what I was referring to last night but still got stuck). Im on page 9/22 and Im confused on what file from madselectronics to download.
Old Jan 25, 2009 | 10:57 PM
Looking at the pictures, my 7zip says 7z464, the one in the picture says 7z442. Does that make a difference? I read ahead and what I meant to say before is that when I connected the smarty to the computer, it doesnt open up the 'new hardware found dialog'. I think it is the latter which means I installed it wrong. I tried to uninstall it per the directions on madselectronics but I cant find the file in my add/remove window
Old Jan 25, 2009 | 11:10 PM
Spooler's Avatar
Yeap, It didn't see the Smarty USB driver. It may or may not have used the correct one. Re-download the Smarty USB driver and install it before hooking your smarty up to your computer. After all this, try it again if you haven't figured it out. Gotta love the plug-fix-play microsoft operating systems. Sometimes it is easy and other times it is a pain.
Old Jan 25, 2009 | 11:16 PM
Spooler's Avatar
SmartyUSB.exe depending on which operating system you have you will need either the 5.07A or 5.07L. Plus you will need the smarty Revo tune and the
7zip program. Put all of this in a new directory on the C: drive where you can find it again. Name the directory Smarty. That way if it needs to find the driver you point it to this directory manually.
Old Jan 25, 2009 | 11:37 PM
Spooler's Avatar
Well, did ya get it fixed up? The first time updating the Smarty can be fun but not too bad. Just a learning process.
Old Jan 25, 2009 | 11:44 PM
Im trying it right now...
Old Jan 25, 2009 | 11:46 PM
ok I got the files and everything. Now my next step is the whole new hardrive dialog thing not coming on. Everytime I plug it in, the dings but no new window...
Old Jan 25, 2009 | 11:53 PM
Spooler's Avatar
O.K. Go to where you saved the Smarty files and double click on the Smarty USB. What operating system do you have? Windows 2000, Windows XP, Windows ME?
I think I have XP
Old Jan 25, 2009 | 11:55 PM
Spooler's Avatar
So, the USB driver should be 5.07A.
Old Jan 26, 2009 | 12:03 AM
what do i do after I click on the smarty usb?
Old Jan 26, 2009 | 12:04 AM
continue with the instructions from larrys link? or do I have to do something else first?
Old Jan 26, 2009 | 12:08 AM
Spooler's Avatar
Yeap, continue with the instructions from Top's link. All should be well.... Hopefully. I just plug my Smarty in and it didn't bring up the Smarty USB either. Good luck to ya.... Gotta go to bed. You should be good to go.
Old Jan 26, 2009 | 12:09 AM
Thanks a bunch, it seems to be working. I will try it on the truck tomorrow morning.
Old Jan 26, 2009 | 12:35 AM
jgiachino's Avatar
What software? Guessing Revo....There's a lot of settings available, start small and work your way up.....would think a good starting point would be default timing, tq mgmt 2, rp 2, wg = off.....and maybe power level 5....you need to be reasonable careful with a stock transmission...as smarty on the higher levels or more agressive settings (tq mgmt 4, rp 4)....can be very hard on a stock trans....
