turbo's and mileage
Old Jan 31, 2007 | 11:55 AM
Agades's Avatar
turbo's and mileage
What are you guys seeing your mileage do when you "upgrade" to a different turbo
for example a phat shaft or comparable turbo?
Old Jan 31, 2007 | 12:00 PM
rstone's Avatar
in your sig you show you have a 62/14 already how has your fuel mileage been with that turbo.
Old Jan 31, 2007 | 12:02 PM
Agades's Avatar
it dropped 3-4mpg
Old Jan 31, 2007 | 12:10 PM
rstone's Avatar
That not good I maybe might not considering in getting one now if it drop in that much fuel mileage. Keep the post coming I really like to found out I out because I am thinking of buying one now
Old Jan 31, 2007 | 03:06 PM
rstone's Avatar
Anybody else is loss alot on there fuel mileage when adding a aftermarket turbo.
Old Jan 31, 2007 | 11:03 PM
BlueDually's Avatar
I lost mpg also, but also added 295 tires and a body with more drag at the same time.
would the stock turbo in a set of twins keep the mpg up?
Old Jan 31, 2007 | 11:04 PM
D.Wiggs's Avatar
With all of my mods, my MPG has gone up between 3-4 MPG. The Smarty made the biggest difference because it uses more motor and less turbo.
Old Jan 31, 2007 | 11:14 PM
stock03's Avatar
With the Super-B I went up about a mile over-all. The spool up is just a little slower than stock. But of course I have one of the smaller/lower HP turbos. That's all I could afford at the time.
Old Feb 1, 2007 | 03:17 PM
RamWheelsBy4's Avatar
I don't think I lost mpg with the SPS66, but too many things went on at the same time to know for sure. I do know that currently with my daily driver triple stack my mileage is better than it has ever been. Not great, but much better than a year ago or so. I can guess that it is the addition of the Smarty in the stack. I average 15mpg city and 18.5-19.5 highway at 75mph depending on the terrain and wind. That is at least 2mpg better than it was for over a year after new.
Old Feb 1, 2007 | 04:45 PM
acook's Avatar
I went up a mile or 1.5 when i did my twins, seems even better when towing.
Old Feb 1, 2007 | 10:57 PM
morkable's Avatar
My mileage dropped after I put on my turbo,, but now that I am getting used to it (not putting my foot into it so much anymore,, lol) my mileage is about the same as before.
Kevin
Old Feb 2, 2007 | 02:04 AM
streetsmoker's Avatar
Mine was virtually unchanged.
Old Feb 2, 2007 | 11:03 AM
BlueDually's Avatar
Has anyone noticed more of a change/drop when towing with a single?
acook, your idaho twins use the stock turbo on top right?
Old Feb 5, 2007 | 11:03 AM
Agades's Avatar
I would like to know more about the Idaho twins
any info?
Old Feb 5, 2007 | 11:06 AM
Agades's Avatar
my towing mileage is about the same as the stocker
its the cruising empty thats wayyyyy down
