Turbo, Remove ?
Turbo, Remove ?
Should the turbo be removed when tapping manifold for EGT probe ? I plan to install gauges this weekend ( EGT , Boost & Trans temp ). From what I've read egt probe should be installed pre turbo. Should the top or side of manifold be tapped ? Can this be done when the engine running to blow out any shavings ? Help ? Don't want to screw this up !!! Love this truck !
Thanks
Brad
Thanks
Brad
I am looking at doing this same thing in the next few months.
Does anyone have a link to a website with some pictures. It sure makes us stoopit people feel better ( or at least it makes me feel better about what I'm doing
) when we have some pictures to look at!
On Edit: Thats not my truck in the pic, I did a random google search and came up with that but mine looks very similar. It's really not very hard to install just take your time and make sure you have the right size drill bits and tap.
Did mine w/o removing the manifold. I used vaseline on both the drill bit and tap. While drilling and tapping I would frequently stop and remove any shaving with my telescoping tip magnet. After I was complete I gave it a final sweep with the magnet then started it up. Be sure to use a bit of anti-sieze on the threads of the sensor. When you're done you'll wonder what all the fuss was about.
I went the xtra mile and had my shop vac on while I drilled and then what all the others say.A couple beers help me get over the nerve wracking feeling of installing my gauge pack. Yup wondered what all the fuss was about.Well I did mess the tranny pan,but we wont go into it.Took enough abuse from my camping buddies
I use the grease on the bit and i place a magnet on the manifold next to where the hole is being drilled, but if you start the truck rite before the drill breake thru, there is enought ex manifold pressure at idle to keep all trash out, leave it running while you tap the hole.
Note: Wear Goggles, and gloves while tapping
Rick
Rick
