Turbo question?
Old Jun 17, 2008 | 11:19 AM
05 Thunder Beas's Avatar
Turbo question?
I am looking for some help from the gurus here. I have what I think is a turbo problem. Driving down the road with 3/4 or more throttle the engine will hit around 22 psi boost and then blam the boost drops and the truck lurches for a split second. It seems to be sluggish and when cruising at 65 in cruise control there is 0 psi where it used to be up and down from 4 psi up and down depending on the road. I have been running a quad boost fooler and bully dog and it is the stock turbo. Does this sound like the turbo itself or a boost leak? What happens to a turbo when it goes out? Thanks in advance.
Old Jun 17, 2008 | 03:27 PM
Big Blue24's Avatar
Take off the filtered air inlet tube and grab the bolt/nut that holds the turbo impeller in place. Try to wiggle it up and down, side to side, and in and out. If it has more than 1/16" play, it is worn and could be nearing it's life cycle.
I would guess you are either draining the rail by faulty fca or low-no lift pump pressure, your truck is going into some sort of a limp mode, or you have a big boost leak.
I would guess boost leak first, rail pressure second, limp mode third, bad turbo last.
Old Jun 17, 2008 | 03:31 PM
dodgezilla04's Avatar
i would start by removing the BD and see if it still does it.
then i would remove the boost fooler and see if it still does it.
more than likely its a hickup caused by the electronics...
Old Jun 17, 2008 | 04:01 PM
browndg's Avatar
I had the same set uo until yesterday, my out lok would only 22psi boost then stop, the problem started when i ran the boost fooler. chaged to smarty on yesterday, now upwards of 35 psi. check the boost fooler.
Ada381
Feb 10, 2008 07:58 AM
j
Jan 9, 2004 08:19 AM
Haulin_in_Dixie
Jul 21, 2003 11:14 AM
redram
Dec 10, 2002 09:54 AM
