TST is off the truck and headed back
The performance end of the TST is just awesome but the functionality isn't working. The cool down feature of my r49 doesn't work (truck shuts down immediately), no matter the settings. Anyone else had this problem?
Danny sent me out a new timing harness but that didn't change anything so I had to take everything off and send it in.
Questions is, should I get the Twins version and adjustable timing while it's in? I am almost certain I will get the adjustable timing but what about twins? What does it do? Explain please.
I believe the tst starts fueling around 12lbs, with the twins program it fuels way before that! I could be way off hear but the regular program starts fuelin at 12lbs and is at max fuel at around 30lbs, the twins program it will be at max fueling around 12lbs. Someone please correct me if im wrong, cause like i said i could be way off!
Originally Posted by 05mxdiesel
If you plan on keeping a stock turbo for a while do not get the twins version. It will be too hard on the shaft of the turbo.
Guys, I don't think they call it twins because it looks like a set of ooters. Its meant for high volume air supply such as a super single or twins. A 66/12 or equivalent is the smallest to use the box's potential. Sure it will work with a smaller turbo but I don't think it will run cool. ks
Regular program starts fueling at 12psi and ramps up to full fueling at 30psi.
Regular twins program (for 04.5 and up trucks, or '03-'04 trucks with injectors, TST says) starts fueling at 4psi and ramps to full fueling by 24psi.
Early twins program (for '03 and '04 trucks w/ stock injectors) starts fueling at 4psi and ramps to full fueling by 12 psi.
I have the early twins flash, and if I had to do it again, I think the regular twins program is what I'd want. Anything over about 3x2 gets really peaky and will bark your turbo a lot if you're not careful.
I just don't believe people that say the drive with early twins flash on 5x5 every day. It's like driving an old, peaky 2 stroke 250 dirt bike. Once it "gets on the pipe" look out!
I made my numbers with the standard program. It's no slouch.
Originally Posted by PsRumors
Questions is, should I get adjustable timing while it's in? I am almost certain I will get the adjustable timing but what about twins?
I think what he's talking about is an adjustable EGT cool off timing thing. I think. I could be wrong. Don't hold me to it. Oh please don't hurt me if I'm wrong. I promise I didn't mean it. Oh no, the cops are here.......
Originally Posted by Tomeygun
I have not heard of the adustable timing, Do you mean you can actually adjust the max timing used in the box?
$50 upgrade if you want it done, although I imagine you'd qualify for a freebie.
Another cool thing I learned today, it doesn't matter what remote you have, the boxes themselves are all the same. If you want to buy a second box it doesn't matter what it is. It can be upgraded to work with your remote.
I'm looking on a deal on a used one so I can have BOTH twins programs...
Does anyone know at what boos level the "Original" TST starts fueling and when it is all-in? By "Original", I mean the very first ones they producted that were so hard on turbos before they retuned it.
Is anyone running one of them and making high HP. If so, what other mods do you have?
Totallyrad
Sep 25, 2011 02:24 PM
DrMike
71
Jun 15, 2008 08:57 PM
Tommy93w350
Aug 7, 2007 12:15 PM
JoshPeters
Apr 3, 2005 08:13 AM
passnu2
Dec 19, 2004 09:09 PM
