TST & MP-8 STack Question
I currently have the TST into the Map sensor first, and then the MP-8 into the TST. Is there any reason to reverse them with my setup? Is it worth the hassle? I am a little confused as to what the difference would be.
Thanks!
Thanks!
If you want the stack to work properly, you want the MP-8 in the MAP sensor first. The MP-8 inflates the MAP values at low boost to get the TST to fuel harder on the bottom end. It really wakes the TST up, more so than any other pressure box. I love mine!
That's what I'm gunna do !
Here is a technically ignorant question that is unrelated:
How do I adjust the max boost on my ATS Twins ?? DO I need a boost controller? I feel like an idiot for even asking! LOL
I will be breaking them in, although, as I was talking with the techs about it; they were not exactly sure why it would be necessary. Obviously the motor is new, so it need broken in. But they were saying, after looking at the turbos, that they were really ready to go out of the box, and that the clutch needed some breaking in. I am one to always err on the side of caution so that stuff doesn't break in the long run, I am just not sure what could break on this setup. It seems that if it were good enough to go; not much is going to change in a few hundred or thousand miles.
You'd be surprised. The bearings in the turbo's need to break in and loosen up, the studs need to be heated up and retorqued, the clutch needs to be burnt in and worn in, the pistons rings and cylinder walls need to file themselves smooth, main bearings need to work in, lifters on the cam need to wear in, lots of stuff needs to break in and loosen up and work with each other. It doesn't take long though considering how fast those parts are moving.
