Tst ?
Tst ?
Ok been running my TST for 6 months now. Truck is a 04 HO DRW QC 6spd 4" exhaust straight through. 2/2 feels nice like a stronger version of a cummins. 3/3 feels at bit sluggish when you gun it in 2nd gear from 1500-2200rpms and then it flushes through smoothlyh to 3000rpms. from level 3/3 and beyond i get this "SLUGGISHNESS"........what is it??? I would rather prefer smoother overall power then feel this BOOGGGINESS.... This would be the only thing I dislike about the TST...
someone help me cure it!!!
Originally Posted by big red psd cc
Its the characteristics of the TST. It does not fuel worth a darn til 12psi.
I have the twins program, and it still does it. By the time it fuel, the race is over with.
But lord have mercy, when it does fuel......hang on!
no i believe i am already past 12psi ... this even happens in 3-4-5-6 gears... start from 1.5K rpms and get on the gas at 4/4-6/6.. and you feel this sluggishness....... i'll try it again and see if i am past 12psi....@1500rpm in 3rd at WOT......
Originally Posted by BLKHO600
will any other add on system work with the TST... I have the version with EGT and Boost gauges...
is this call stacking when you use two units???
I second the motion for you to try a EZ stack with your TST. I love it. With the TST on 3x3 & EZ on 2. It picks up the 12 psi lag nicely. The only thing is that this will put you border line for needing a fuel system upgrade & clutch.
mjpalmer
May 19, 2005 11:34 AM
WhiteSport600
Dec 23, 2004 09:59 AM
BCobb
Jul 11, 2004 01:49 PM
Zino
Aug 15, 2003 10:14 PM
