Sponsored by:
Sponsored by: DashLynx
TS Performance Ramifier
Old 02-03-2004, 09:29 AM
Fummins's Avatar
Dennis
Thanks Dennis,i found it.I could not find much in the way of info on the Ramifier though.i.e. dyno charts,egt info,etc.Is this info available? Thanks,Mark.
Fummins is offline
Old 02-03-2004, 02:42 PM
sawboywv1's Avatar
REBADGED Edge EZ....
sawboywv1 is offline
Old 02-03-2004, 03:03 PM
Fummins's Avatar
Nah,i dont think so,they claim 100 @ 125 h.p respectively for H.O and S.O. applications.Never heard of an Edge doing that.......
Fummins is offline
Old 02-03-2004, 09:03 PM
gatorac's Avatar
TS Performance has just released the new RAMifier module for the 2003 & 2004 Dodge Cummins. Add 100 RWHP to your HO Dodge and 125 RWHP to your Non HO Dodge.
A little more technical information might be helpful for those of us trying to make a desision on wich box to buy.
gatorac is offline
Old 02-03-2004, 09:55 PM
zzsdad's Avatar
Still not what the TST is claiming. That TST gauge package looks cool. Still not sure about giving up the warranty.
zzsdad is offline
Old 02-03-2004, 11:24 PM
Battering Ram's Avatar
I cant really get a good idea of how the Ramifier works from the pic. Looks like map sensor hookups and map sensor... but there also might be another. Are you seing these results from fuel pressure alone? If you are that is pretty inpressive for just fuel pressure adjustments.
Horace
Battering Ram is offline
Old 02-04-2004, 01:59 AM
AK RAM's Avatar
Hi Dennis,
If you don't mind, can you explain for us exactly what modifications the box is making to up the HP and Trq? Timing: how much. Rail pressure: how high. Things of that nature.
This might clear up a lot of questions if we all know the basics to start with.
Thanks
AK RAM is offline
Old 02-04-2004, 06:56 AM
sawboywv1's Avatar
Yeah, How does it work? That's alot of $ for a pressure box.
Old 02-04-2004, 09:30 AM
doug's Avatar
if it plugs into the pressure port, its a pressure box.
if it makes more than about 70 HP its more than a pressure box
If it doesnt' hook up to the injectors directly then it can't be duration.
Therefore, the "more than 70 HP" must be timing...
This sounds like a pressure/timing box. 100-125 HP is the clue because you cant' make that much with pressure only, and there's more than that available via duration/timing. so is it a pressure/timing box?
doug is offline
Old 02-05-2004, 05:24 PM
doug's Avatar
where are its physical hookup points?
doug is offline
Quick Reply: TS Performance Ramifier
