Truck not warming up...
I recently installed the majority of the upgrades in my sig. I can drive almost thirty miles without getting the thermostat to open. The truck only gets to normal operating temperature if I pull a long hill and put some boost to it. I dont want to beat on the truck while its not warm so I never get to use the skinny pedal. Cam, compunds? What could be causing this? I just had the entire heater core flushed becuase I blew my HG so that is prisine and has a brand new thermostat.
Honestly, I'd say it was a bad thermostat that was sticking open...none of the other mods would do anything to help you run cooler, and most will make you run hotter...
Just a tad more info would help narrow it down:
Pyro temp?
Coolant Temp at start? (Where are you reading the temp) Don't go by the factory gauge.
Coolant temp after 10 or so miles?
Outside Air Temp?
I've found with my ride if the engine isn't under some load, it will not warm up. Even at high idle it won't get over 135-140F. That being said, I'd pull the thermostat and check for damage as well as its operation by putting it into a pot of water and slowly heating it up. Thermo should open just before the water simmers. If it opens way before, then you found the problem.
The other thing you can do is put a piece of cardboard in between the rad and the intercooler to see if that helps.
Pyro temp?
Outside Air Temp?
Are going by the 'idiot' gauge on the dash? There not the most reliable in terms of an accurate temp.
Air in the system would cause an overheating situation. I'd put money on the thermostat being bound open. If placed in a pot of water on the stove to test for proper operation, it should open around 195*.
One of the great things about a diesel engine is how efficient they are. Try and get a gas engine to make 650 ft/lbs and still get 20mpg.
Heat is a byproduct of energy production. The more efficient the engine is, the less heat it will produce.
Power mods for any engine primarily make the engine more efficient.
Do you have a winter cover?
Actually air in the system can cause a few different types of situations. Usually just a lack of coolant will cause an over heat condition that the sending unit in the head can detect.
However air in the system introduced by a leaking head gasket will cause the coolant temp sensor to read low, even though it is probably running hot. Usually the heater doesn't work either until rpm is increased.
I am using the idiot gauge. The truck used to warm up much quicker. If its under load like climbing a hill it will warm up. But just crusing at 65 it stays at just over a quarter on the temp gauge. It is winter but even when its in the mid thirties it takes alot to get it warm.
