Truck has the Buck
Truck has the Buck
Ok guys I need some help.
My truck will buck some times, meaning it will sort of stall under throttle, most of the time it is under heavy throttle. I have elimanated the fuel filter,and the air filter as being the source ( both changed out). I notice when i change SW on the smarty it goes away for a while. I hope this make since, the bucking is annoying, ans sometimes it just goes away ??
No noticeable change in any of the gauges when it bucks, I have watch them closely, do you think this is in my programmer ?? it did it before the power puck was added.
Could be the same issue we are seeing on '03-04 models using the SMARTY with the timing cranked up. Try reducing the timing using the aftermarket injectors settings and see if the issue goes away.
MikeyB
MikeyB
randyeller
12-16-2007 02:54 AM
jtalaiver
20
06-22-2007 10:36 AM
