Trouble with pyro
Old Oct 30, 2005 | 07:32 AM
doug60's Avatar
Trouble with pyro
Pyro is acting erratic , drops out 300 degrees then back up. sometimes falls all the way to 250. I shut the truck off when it read 250 and it went to 400. anyone have this kind of trouble, its a diprocol gauge. Also there are two 12 volt feed wires ,to it plus the lighting wires. What do they do ?? My pyro in my 96 doesn't have them. thanks, doug
Old Oct 30, 2005 | 10:11 AM
DR3500's Avatar
after shutoff, it is normal for the EGT's to climb up some since the heat isn't being pushed out anymore. All the wires on the gauge except the ones in the plug are illumination, it has the normal bulb AND LED's.
Old Oct 30, 2005 | 07:26 PM
doug60's Avatar
This movement is not normal, the needle is moving around like a ball, in a pinball machine.
Old Oct 30, 2005 | 07:28 PM
doug60's Avatar
There are 4 wires in the plug, plus 2 per bulb.
ridlangus123
Dec 30, 2013 08:36 PM
nrobert10
Jan 6, 2013 01:30 PM
schamran
Sep 2, 2009 03:20 PM
Clay
Mar 21, 2003 10:53 PM
RAMTECH
Mar 9, 2003 12:49 PM
