Triple dog problems, no smoke?
Ok I got a Triple Dog today from a friend. It is version 2.4.0. I loaded it up and gained some power but no smoke and I still can barley hit 1300 degrees. When I go to select my power level I select extreme and then yes and yes once more to continue but then it takes me back to the same power selection screen with out loading anything.... The truck does have more power but not near as much as I expected. I changed my tire size so I know its working, any ideas?
Ok update, the truck ****ing runs! Maybe its the 90hp of pressure/Boost fooler with just a tow/haul setting since there is still no smoke. Im pretty confused we loaded up a quadzilla programmer a little while ago and she would black out highways, with the BDDL I get nothing.
I was equally disappointed with the triple dog on my '03. On extreme it made 66hp on the dyno. Whoppeee!!! Smarty on the same truck made closer to 150 (advertised 140 IIRC).
The BDDL did give great throttle response compared to stock, and made the truck rip when stacked with pressure (original quad race, an EZ, and a MP-8), and stacked with a TST and supporting mods got my truck to 555/960 uncorrected.
Is it the latest program that you have? Maybe a newer program may be better?
Nope even with pressure off I get nooo smoke, not even a haze. Pressure on I get a slight puff of smoke. There is no quad on the truck, I was just saying a little while ago I tried one and it smoked like a freight train and pulled hard! Something has to be wrong here. Do you think if I loaded up 2.4.d it would run better?
CReed
May 17, 2007 10:11 PM
acook
22
Sep 23, 2006 12:46 PM
Thenewguy
Jun 1, 2006 03:20 PM
RamWheelsBy4
Sep 17, 2005 01:43 PM
JUSTIN1MC
Aug 12, 2005 12:01 PM
