Trans work
Guys, my truck is obviously screaming it needs a trans, whats the bare minimum I can get by with? Would I be OK to just do a VB and TC, thats the extent I'm capable of doing on my own. Also do I need my trans rebuilt or would it be OK just to upgrade those parts, It seems to be in perfect condition now.
The truck pulls often, will probably never see a drag strip, will never see a sled. I would like to be able to put smarty on #9 and not worry about frying stuff.
I could put a larger turbo on in the far-out future, but not to the extent of needing head work, ect.
I'm in the same boat as you I just want to be able to turn the Smarty up and play a little. I'm currently saving for a TC, VB, billet input shaft. From everything I have read that should hold a good amount of HP if you use your brain with the go pedal.
I can't seem to find it on their website at the moment, but they do have one. It's what I run in my truck, and after being the guinea pig - my idea, it's what John at Floor It is using for customers.
http://www.transmissioncenter.org/contact_page.htm
Don't skip the flexplate while it's apart. You can get a very strong SFI flexplate that's much stronger than the stock one for $160.
See if you can get a hold of John at Floor It and talk to him about the TCS converters. He uses them quite a bit. I personally wouldn't run a single disc, but there are a lot of guys that do. I believe the pressure has to be turned up even more and then you have really hard shifts. Some guys like the shifts to feel like the tranny just fell out.
03CTDCO
Feb 27, 2005 07:30 PM
