trans gauge not reading?
so i installed a isspro trans gauge in my truck on sat and i believe it is not working. the needle doesnt move, at all. i have the sensor in the pan. do i have to maybe ground the sensor from the pan to the frame? or is something else the matter? thanks for your help.
Is the truck up to temp? My gauge does not read until I've been driving for about 5 minutes.
I had a problem with the wires pulling out of the amp box... they still looked hooked up, but were not.
I can't remember exactly what the hook up procedure was, it's been 6 years.
On my amp, there were screw terminals on the side for the wires to go in to, you just tightened it down.
Is your tranny locked when driving? If so it may keep the temp down pretty low and depending where your gauge temp reading starts you might not see it until it gets hot. Mine starts at 100* F. During the winter, with my tranny locked in town I usally don't see anything above 100* unless it's stop and go. Just a thought. Good luck.
how did you ground your trans gauge. also i have a deep pan with cooling tubes on it. i felt the trans pan after driving it in the morning and it wasnt all that hot prolly somewhere around mayb 130? not as hot as a hot shower i could keep my hand on it no problem
yeah i think it is the ev2's im gonna have to go through the wiring tomorrow
no 6 how is the box grounded? do you have to put another wire on it or dont you just plug it in to the gauge and the other end in the sender i didnt see anything about grounding the box? thanks
Hmmmm....I thought the instructions called for grounding the box. Is there a control box for the trans temp on an EV2? Oh, I think they use the harness ground to the gauge as the ground for the stepper motor. Thats the way the boost gauge is wired.
yeah there is a control box but you dont ground it like you do on the pyrometer i know exactly what your talking about. i lost my trans gauge directions there is no wire for power and no wire for a ground like you would think maybe im wrong ill have to check.
mullishacrew
Mar 18, 2012 12:41 PM
CTD2001
May 1, 2010 07:46 AM
gpshemi
17
Jan 17, 2010 08:32 AM
Vitamin C
Mar 1, 2007 06:06 PM
cantfindaname
Aug 13, 2004 10:44 AM
