train horns
train horns
so me and some buddies are doing a group buy on some horns, i was wondering where are you guys mounting them on your trucks? i was thinking where the spare is....
Depending on the horn size. I mounted the Hadley Bully Horn (twin horns) inside of the fender after removing the inner fender well. This keeps the horns dry and you get a little more noise because of the echo. The tank and the compressor are mounted just behind the driver side fog lamp.
I'm curious about a groupbuy (pm already sent, lol).
Does anyone have their horn installed behind the front bumper area? ~ unsure how big these truck horns are or if there would be enough room.
There is not much room in front of the bumper. Especially if these are the triple horns. But if they are double horn then you could put them behind the fender liner. Its only 7 or 8 screws then up near the top of the inside fender. Then you have room for a small tank and the compressor behind the fog lamp on either corner. But the driver side is easier because the horn is on that side and you have to run a wire inside of the truck
I got the horn, but need a new compressor, see what they can come up with or pm me the site that you are buying from so i can shop it for compressors...... mine is mouted on the frame rail under the pass seat/ floorboard, compressor mouts to the transfer case skid plate, tank where the spare was. picks in gallery
I have train horns on my long bed. TONS of room between t-case and fuel tank. I turned them rearwards to keep mud out of them. Compressor on the passenger framerail 6 gallon tank on under side of bed. I have an electric solinoid valve to activate the horns..
