trac bar heim joint
Old Dec 12, 2011 | 05:33 PM
rjm022's Avatar
trac bar heim joint
i have a well known after market trac bar with a heim joint and every two years i have to replace the heim joint because it is shot. anybody else doing the same?
Old Dec 12, 2011 | 06:05 PM
spooled05's Avatar
Yes , and bushing also!
Old Dec 12, 2011 | 07:19 PM
rjm022's Avatar
nice. i thought they would of lasted longer.
Old Dec 13, 2011 | 08:40 AM
.boB's Avatar
That's pretty normal. Heim joints are nice because they are almost zero friction - no binding. The down side is that they wear out rather quickly.
Old Dec 13, 2011 | 09:36 AM
gpshemi's Avatar
Wow. Considering the cost of heims, I'm glad I found this out now. Glad I stretched my factory arm. I'll just throw in some better bushings when it's shot.
Old Dec 17, 2011 | 09:12 PM
trik396's Avatar
How does one know the heim is going bad??? Mine has been in over two years.
Old Dec 17, 2011 | 09:24 PM
.boB's Avatar
The wear usually occurs inside the bore, where there's unprotected metal to metal contact. Loosen the boltthat clamps the joint together, and give it a shake. There's always a little bit of slack, but it should not rattle. If it rattles, replace it.
A good joint will have a teflon lined ball. The teflon will usually last a lot longer than than the bore does. But if you use a cheap joint, there's no teflon. So you get wear at both places.
Spend the money and get a quality steel replacement. Aluminum components do not belonge there.
I don't recommend a rod end with a zerk fitting. The hole for the fitting creates a weak spot, and decreases the load capacity of the part. And you're not going to grease it anyway.
Also, I highly recommend a rod end seal. Use a dry lube and a seal washer to keep all the crud out. Don't use grease - it's a dirt magnet.
http://www.summitracing.com/parts/SIT-WS6250/
rockittboy
0
Feb 17, 2012 05:02 AM
YounanDiesel
Nov 17, 2011 06:02 PM
89dieselkong
Feb 12, 2011 10:06 PM
rjm022
Sep 3, 2009 02:55 AM
bradler
Mar 17, 2009 09:59 PM
