Top speed?
I guess I don't get why anyone would want to take a 7500lb+ truck over 100mph. Don't get me wrong, I'm a speed junkie, but I like to do it in a car or on a bike. I guess the next thing we'll be seeing is how fast we can make our Petes or KW's go.
BD is a company name and i should work fine with all programers, boxes, or whatever else is out there. If i had a manual i would look up which wires to tap for and 03. Maybe if i get time tomorrow ill stop at the dealer to check there manual. If anyone else already has one please chime in on what wire is hooked to the abs.
do you notice any dfierence in power when you turn off the abs?i did it on my 04 and my power was almost half,maybe the diablo uses the speed sensor for somthing,i put the fuse back in and bang power was back.
careful guys this stops your speedo also, dont get caught with a switch wired into your abs system, if the dealer sees this you may have questions to answer, and a lights come on in the dash also, just temporarily pull the fuse if you want to play.
