Took the HEAD OFF today..PICTURES*****
Old Apr 14, 2006 | 06:32 PM
PourinDiesel's Avatar
So far it looks like most of the intake valves have "made contact" with the tops of the pistons at some point...
Most of the pistons have a little build up of carbon on them as well as the head surface.
The #6 six in the pictures has alot of carbon build up which I cleaned off.
There is some pitting on the tops of some of the pistons from overfueling.
All of the cylinders have some lines but they cannot be felt by finger nail or tip.
Engine has 32k miles.
I am going to take the head apart and inspect the valves to make sure they are straight. I will also be installed a new set HD valve springs to prevent contact again
The headgasket is in *decent* to good shape but thats about it. It is in the early stages of coming apart around the cylinder edges.
I also bottom tapped all of the block holes.
Old Apr 14, 2006 | 06:34 PM
Old Apr 14, 2006 | 06:41 PM
mikmaze's Avatar
and one more pic coming to show the valve side of the head , interested on hearing ideas on what kind of shape they think that motor is in.
Old Apr 14, 2006 | 06:48 PM
Rolngthun's Avatar
What was the issues you had, that you took her down?
It looks pretty good really. Tough to tell in pictures I guess.
If it did hit the valves, be very careful. I have seen the heads come off after contact. I can't say for sure on the B engine. But most valves the head is actually seperate from the stem. I believe they are spun welded, for lack of a better term, together.
Old Apr 14, 2006 | 06:49 PM
I am doing some uprades:
A new Cam and Valve springs.
I also needed to bottom tap the block holes for studs.
Old Apr 14, 2006 | 06:51 PM
BigBlue's Avatar
I thought you already had a new cam in there?
Old Apr 14, 2006 | 06:55 PM
Going more aggressive
Old Apr 14, 2006 | 07:00 PM
BigBlue's Avatar
Ahh. So that way your valves hit your pistons harder?
Old Apr 14, 2006 | 07:04 PM
Blue,
The new springs should prevent that.
Old Apr 14, 2006 | 07:06 PM
mikmaze's Avatar
no pic of the valve side of htings???
Old Apr 14, 2006 | 07:12 PM
Old Apr 14, 2006 | 07:14 PM
mikmaze's Avatar
what a guy..... good luck with the project and let us know how the upgrade worked out for ya, aggressive cam can do a lot for ya.... have fun with it.
Old Apr 14, 2006 | 07:16 PM
Really what I think my engine could use is a 10k lb. trailer pull for about 500 miles to burn all the carbon out.
The truck is just a grocery getter other than sledpulling about 10 times a year.
Old Apr 14, 2006 | 07:27 PM
Dieseldude4x4's Avatar
You can see the spray patterns on the piston tops real well.
Old Apr 14, 2006 | 07:53 PM
Jeff K's Avatar
If you have the head off, why don't you drill and tap the block for 14mm head studs? Can't you change valve springs without removing the head? Who's cam and valve springs are you going with? Good luck with the upgrades I did my cam install a couple weeks ago with the head on. It was actually not that bad of a job. Keep us updates!
