Tone Ring Mod?
Old Jan 16, 2006 | 06:23 AM
sawboywv1's Avatar
Tone Ring Mod?
Can the ring be rotated too far? Or, are the bolt a limiting factor? I did mine yesterday and was wondering if it can turned too far.
Old Jan 16, 2006 | 08:06 AM
Dodgezilla's Avatar
If you have a lot of rattle, you went too far. Every truck seems to be different so if you aren't hearing a bunch of rattling I'd say you are OK. Soem guys are even hogging out the bolt holes to get even more timing. I ended up having to turn mine back some because I was getting too much rattle for my liking...
Old Jan 16, 2006 | 08:26 AM
sawboywv1's Avatar
I only noticed rattle when cold and really not too much more than usual. Not at all when warmed up. It did feel alittle weeker at RPM's over 2k though. Is that what you noticed also? Maybe in my head?
Thanks
Old Jan 16, 2006 | 11:08 AM
Dodgezilla's Avatar
I feel more power on the bottom end with the mod. I initially turned the ring backwards and felt a power loss. Are you sure you spun it the right way? It's real easy to screw up when you are laying upside down....
Old Jan 16, 2006 | 11:13 AM
Hoss's Avatar
Thats MR Hoss to you buddy!
What kind of moron would do that??
Old Jan 16, 2006 | 11:31 AM
Dodgezilla's Avatar
Not me! Why? Do you know somebody stupid enough to do that?
Old Jan 16, 2006 | 02:32 PM
Hoss's Avatar
Nope!! And if I did I would never admit it!!
Old Jan 16, 2006 | 02:47 PM
BigBlue's Avatar
It really just depends on the truck. My buddy is running an EZ with the tone ring moved all the way and he doesn't have any timing rattle at all.
Old Jan 16, 2006 | 07:34 PM
C Schomer's Avatar
Mine is stock. The first time I advanced to 2.17 degrees and had rattle and still picked up .5 mpg. Then I went back to .110" or 1.57 degrees and picked up another .5 mpg and engine sounds happier and running more freely - I'll leave it there. Both adjustments were just random choices but I measured with a dial indicator for reference. Craig
Old Jan 16, 2006 | 07:43 PM
Herrin811's Avatar
I moved mine about 3/4 of 1 tooth...2-3 degrees I guess....Great mileage...I dunno what you guys would think of it, but I think it sounds awesome....My truck definitely doesnt sound like the virgin 325 dually at work....Sounds better to me....Several people have comments on its "industrial" tone
(still trying to learn what all the little sounds are, and what you guys mean by rattle, ping, etc...)
I wish we could adjust the timing while the engine is running......That would be nice Cough Cough Quad Ahem Cough
Old Jan 16, 2006 | 07:53 PM
fast_enough's Avatar
The 2003 HO's have quite a bit of advance already. I put mine back to stock.
Old Jan 17, 2006 | 06:53 AM
sawboywv1's Avatar
SuperDuty what is too much on a 03 HO. If 1 tooth = 2 degree? (tooth to tooth including nothed section between) ????
Old Feb 4, 2006 | 02:03 PM
dencordle's Avatar
Does this help or hurt when running a edge juice/attitdue???
Old Feb 4, 2006 | 06:14 PM
bama's Avatar
to the bolts seems to be about 2.6 degrees.thats what i measured anyways on mine....funny thing big blue on the ez statement,i took my xzt box off and had more rattle.i put it back on,and the rattle went away.anyone have a thought on this?......and for kicks,i adjusted it backwards just to see what would happen, ,,,it really helps out more than you think..............bama
Old Feb 4, 2006 | 08:04 PM
ed paul's Avatar
i just can"t figure this out,,with a chip add 1-1 1/2 mpg,,tone ring .5-1 mpg,powerservice .5-1 mpg, intake .5-1.5, free flow exaust .5-1 mpg,,synthetic oil .5,,complete synthetic everything 2 mpg,,,,,,,did i miss anything??? and i think I"m using the low estimets on all the claims the manufactures make,,,, not knocking anybody,,,,but why aren"t we up to 24-25 miles per gallon?????
Dodgezilla
129
Nov 18, 2005 11:43 AM
BossHogg
Sep 30, 2005 06:31 PM
Dodgezilla
Sep 30, 2005 12:56 PM
Mark Hodowanec
Sep 29, 2005 09:15 PM
BossHogg
Sep 14, 2005 09:48 AM
