Tone Ring
Old Jan 8, 2006 | 01:43 PM
SSminnow's Avatar
Tone Ring
I have asked a few times in other threads and not gotten an answer, and not to sound like an idiot, but what is the "tone ring" mod?????
Old Jan 8, 2006 | 01:49 PM
kingofdodge7131's Avatar
never heard of it myself either but if its what it soudns like pry some way to change your speedo, or cheet your mileage, so you could drive 100kl and only log 75k something of the sort
Old Jan 8, 2006 | 01:58 PM
CRXsi's Avatar
Search in the perfromance and accesories section...there are probably a 100+ posts relating to the mod.
To answer your question though...the tone ring is the toothed wheel that is attacehd to the crank pulley to generate a voltage at the crank sensor that is then sent back to the ECM so that the ECM can calcualte the crank postion and determine injection timing as result. By modding the tone ring (or installing a modded sensor) you can fool the ECM into advancing or retarding the injection timing (advancing is usually benefitial both for power and mileage).
Old Jan 8, 2006 | 02:01 PM
rico334's Avatar
Did a search and think this will answer your question........
Old Jan 8, 2006 | 05:39 PM
C Schomer's Avatar
There was a thread about 2 wks ago. I found it then and did mine. On mine, just filing the dowel hole allowed almost 1/8" travel which was plenty on mine. Too much and it will rattle - mine rattled on takeoffs but I filed the bolt holes to get some extra. I started at 2.17 degrees. I backed mine off to 1.5 degrees - .105". About .070"=1 degree. I gained .5 mpg - went from 20.2 to 20.7 but I need to use more tanks to know for sure. Craig
Old Jan 8, 2006 | 08:12 PM
CRXsi's Avatar
Not to be smart rico334...but isn't that quote from the post directly above yours????
Old Jan 8, 2006 | 08:20 PM
rico334's Avatar
CRXsi-
Yep, my bad ..... identical to yours. I was doing a search for his answer, copied and pasted, then hit "post" and I think you must have done the same thing just a few seconds ahead of me. If I had seen yours, I would not have hit my "post" button .........
Old Jan 9, 2006 | 04:14 AM
jrs_dodge_diesel's Avatar
Moved to the proper forum.
Old Jan 9, 2006 | 05:44 PM
SSminnow's Avatar
Was not sure of what it was, so that is why it ended up in the wrong section . Anyways, to those that have let me kow what it is, thanks!
HaulinBut
May 12, 2006 03:06 PM
Mark Hodowanec
Sep 29, 2005 09:15 PM
BossHogg
Sep 14, 2005 09:48 AM
VORTEC87YJ
Mar 23, 2005 08:59 PM
