Tire Size
Old Feb 20, 2011 | 04:59 PM
cmiddleton's Avatar
please help tired of getting stuck in wet grass
I just purcahased a 2" leveling kit for my 3500 2wd dually, What size tire will i be able to fit without having any problems, truck still has factory wheels on it. I am looking to put the biggest tire on it possible. please help.
Old Feb 21, 2011 | 02:44 PM
Dirk5.9's Avatar
I'm not gonna be a whole lot of help on this but just to kind of get a response goin' for you. I believe the factory tire size is 265/70R17. I wouldn't go much wider than that with as sketchy as the front ends of these trucks are. There is a guy runnin' some 295 or 305's through town that look pretty good. Again, I would keep in mind the leveling kit, plus a wider front tire, might make the front end wander......hope that helps a little
and Welcome to DTR!
Old Feb 21, 2011 | 05:28 PM
cmiddleton's Avatar
the leveling kit shouldnt make a big difference, it is a coil spacer and a longer shock, factory tire size is 235/80 r17
Old Feb 22, 2011 | 03:57 PM
soulezoo's Avatar
DTR 1st Sergeant
Factory tire size is 265/70r 17
With a 2" spacer, you can run up to 35" tire. Using the stock rim limits width some.
You can do 305/65r 17. I am not sure about 315's.
Old Feb 22, 2011 | 08:24 PM
Lost Lake's Avatar
Lot's of guys run 315's. I had 305's and never rubbed. Now I have 34" tall Nitto's with no rub. 35's may rub a bit at full lock.
I don't think running wide tires on narrow rims is a smart idea. The manufacturer has recommended rims.
oldwhite12v
Mar 25, 2011 04:28 PM
schoust
Oct 21, 2009 10:09 AM
bigdogtruck
18
Nov 21, 2007 08:09 PM
4RnrRick
Feb 27, 2007 11:25 AM
ValkSmile
Jan 23, 2007 11:42 AM
