timming
Old Dec 5, 2007 | 09:02 PM
strokinnsmokin's Avatar
timming
What controls the timming on these freaken 05 dodge cummins????? I really need to figure out why this truck is pinging so bad.
Old Dec 5, 2007 | 09:03 PM
cbrahs's Avatar
fill out your signature with everything you have done to it. People will be able to help you better if they know if you have any mods done.
Dynamic timing though.
Old Dec 5, 2007 | 09:16 PM
testing profile?
Old Dec 5, 2007 | 09:18 PM
Dynamic timing
OK so what is DYNAMIC timing?
cbrahs's Avatar
I don't know much about the crazy lary but someone will chime in. Does it add timing?
Old Dec 5, 2007 | 09:22 PM
Currently I have the truck all factory I pulled the Bully Dog off about 3 weeks ago when I noticed the pinging. No codes have been thrown yet. I ran it by a shop that is known for being the area cummins guy and he said IDONNO maybe your computer.....
Old Dec 5, 2007 | 09:25 PM
CReed's Avatar
Have you checked the injectors out they can cause a know if their cracked and throwing a horrible spray pattern out or if their not firing at all.
Old Dec 5, 2007 | 09:29 PM
tcr's Avatar
tcr
CReed, will you translate that sentence please?
Old Dec 5, 2007 | 09:30 PM
cbrahs's Avatar
i am glad you said that!! lol... got me all confuzzzed
Old Dec 5, 2007 | 09:32 PM
I have not had them checked yet... would they cause the engine to be staying reved up to +-2200 rpm for 2-3 minutes this is with my foot off the pedal?
Old Dec 5, 2007 | 09:34 PM
it will stay reved up until i turn the key off
Old Dec 5, 2007 | 09:48 PM
CReed's Avatar
Bad injectors can cause engine knocking sometimes they will crack and the messed up spray pattern will cause then knocking noise. Other times (when solenoid may fail) and that cylinder becomes dead that can create a knock. This will not cause then engine to rev. like what you described but can at times cause abnormalities in the idle area jumping and then falling at times, also can cause heavy surging. Try getting a new update from dodge and see if that may help, their may be something funny going on in your ecu. Or could be a valve sticking.
Old Dec 5, 2007 | 10:08 PM
well i guess i will run it to the dealer I have always done my own wrenching but this rig is just too computer reliant.
Old Dec 5, 2007 | 10:43 PM
who is making the best aftermarket injectors now? when he hands you lemons Make lemonade
Old Dec 5, 2007 | 11:02 PM
CReed's Avatar
Dynomite Diesel Performance, Formula 1(DON M), or Industrial Injection all three companies can do repairs to your injectors if the problem is in the bodies. Worst case scenario your nozzle(s) are cracked and you have to pay core charge for that one(s) that are bad and then get aftermarket nozzles. All three companies have killer products.
