Time for TOUGH pistons!
Well as some of you may know it hasnt been an easy road to build a high HP CR! Why wasn't 500 HP enough?!
Now its a melted #6 piston! (smarty sw9, mp-8 on kill)
While everythings apart, wanna upgrade to better pistons, and a cam.
What is everyone's suggestion on pistons, and compression drop and cam??
Ceramic coated or not?
How did you get that hot? What were egts? What symptoms led to you pulling the head, again? Dude, that sucks. With twins you should be able to control egt's well, I don't understand, I am making 800 hp right now with no egt problem at all. Jay
Oh, and important question, how much timing advance were you running? If you were injecting very early egt's wouldn't have shown the extreme heat in the cylinder. Dang, you boys get me to worrying on here!!! Jay
Not trying to be a jerk but you need to find what happened or it will happen again. With your twins and smarty and mp8 you should be ok. I would be send your injectors out. Thats the one issue that scares me about these trucks it doesnt matter how well you build the motor or what you coat, if an injector hangs it will easily roast a cylinder. These injectors are the weak point of the motor, and with or without added pressure they can go south at any time.
Good luck, Rye.
Good luck, Rye.
Cummins pistons are all you'll need. Any aftermarket piston will be too soft and not stand up to daily driving. Dropping compression is a tricky thing to do and have the truck still be a daily driver. I wouldn't worry about that.
I think coating is a good idea... some don't. I'd go with ceramic tops and teflon skirts.
As for a cam. there's several to chose from..... F1, Hamilton, Maxspool
how you build the truck depends on what you plans are with it.
I feel your pain. I have melted my engine down twice this year alone. First time was too much timing and the second time was too much N2O causing catastrophic failure. Big, useable horsepower is a learning process and an expensive one sometimes. Go with ceramic coated tops and teflon coated skirts, that will help. From all the research I did Cummins pistons are the best. The aftermarket pistons out there are great but are not really designed for extreme mileage wear. (So I've been told) But remember when you make the pistons bulletproof all that heat will be working on the head then, so make sure your valve seats are upgraded or you will be going back into the motor again for a dropped seat. While you have it down you might as well go ahead and get 14mm headstuds and stud your mains just for some peace of mind. I am dropping my compression this time around as well am shooting for 15-15.5:1 to get a little more air and fuel in there, much lower and it will be a smokeshow when its cold.
But not sure on what grade pistons I'll be using since I have not recieved my head back yet from machine shop after the deck job. Will keep you posted on that. You definitely want to get the bypass from Opie if you can, to help keep the #5 & 6 cylinder temps in check with better coolant flow.
So many ideas! on pistons and compression drop...
Someone suggested the Q480 piston, which i believe is cummins.
Others arias, but then i hear about seizing problems with the forged pistons?!
BTW its a daily driver, and we live at 6,700 feet elevation!
The overheating problem might have arised from too much luging, the wastegate was stuck open, and turbos spooled hard, BTW on the run where that happened timing was on default and SW9 mp-8 on kill. it rattled really bad!
Does mp-8 add timing? or why does it rattle now more then it did with smarty alone?
Im not sure on the egts, cant watch all gauges in less then 12 seconds. i believe they musta reached 1600
