Threw a code please help!
Old Mar 31, 2008 | 05:06 PM
wyocat's Avatar
Has anyone ran into this problem? Today I installed my arson cp3 pump mod and eliminator fuel system. I was driving put the pedal down in 6th gear and threw a code p0088 fuel rail pressure signal above max limit. I have fuel psi set at 15@idle. Whats causing this code or how can I fix it. I was running smarty 4.4 than had Bob send me 4.2 but when i plug my smarty in its reading v4.10c....any info PLEASE help. 307-214-3330 Brian
Old Mar 31, 2008 | 06:20 PM
wyocat's Avatar
bump to the top
Old Mar 31, 2008 | 06:24 PM
Rpainter's Avatar
normal code for modded cp3 get a pressure fooling box and you will never get that code again.
Old Mar 31, 2008 | 06:34 PM
Justice4all's Avatar
The latest Beta 4.2 is a 4.10C tune.
Old Mar 31, 2008 | 06:50 PM
wyocat's Avatar
thanks for all the help...tst in my near future i guess? will the new tnt tune fix that? what are you guys reccomending?
Old Mar 31, 2008 | 07:21 PM
wyocat's Avatar
so i just ran my truck again...no code this time but you can feel it lugging as if its cutting back on fuel...any suggestions?
Old Mar 31, 2008 | 08:44 PM
wyocat's Avatar
to the top...
Old Mar 31, 2008 | 08:57 PM
WYODSL's Avatar
could the pump in combination with the 4.2 be screwing with the truck some how? It almost feels like it is surging any ideas
Old Mar 31, 2008 | 09:39 PM
wyocat's Avatar
anyone????
Old Mar 31, 2008 | 09:49 PM
jwb600's Avatar
if you are running it on sw9 it could be cutting out if its not getting enough fuel. as for the code I get it also on my truck like Rpainter said its common. I just clear it out and keep going
Old Mar 31, 2008 | 09:58 PM
wyocat's Avatar
than what about the surging im getting as if its derating?
Old Apr 1, 2008 | 01:10 AM
Possibly your RV leaking. Try capping the rail and see what happens
TXboy
Jun 13, 2012 08:47 AM
snowmanx
Jan 13, 2012 06:56 AM
StealthRam
Sep 21, 2005 02:27 PM
badram
Sep 6, 2005 05:59 AM
