Testing the TAG...
Old Apr 4, 2004 | 10:45 AM
100 Proof's Avatar
From: Eagle, Idaho. Please set your watch back 20 years when entering.
Ramasaur-
I've PM'ed you and e-mailed you about buying it.
100 Proof
Old Apr 4, 2004 | 11:00 AM
Ramasaur's Avatar
100 Proof....sorry man, I've been working on my thesis for my master degree, haven't checked my email... Got your PM this morning..... not trying to ignor ya
Old Apr 4, 2004 | 11:38 AM
100 Proof's Avatar
I understand the degree thing. Lots of work. What's your field?
Be sure and reply to the e-mail address in the PM as the other is my work address and I won't see it till Monday.
Thanks!
100 Proof
Old Apr 4, 2004 | 08:57 PM
12PACK's Avatar
Re: Tag
Originally posted by jim leal
I just finished my first tank of gas with this thing and gained 1.3 mpg.
You have to switch to gas to use this thing? Wow, that is a mod!
Old Apr 4, 2004 | 10:46 PM
jim leal's Avatar
Typo. Just glad to get better mileage. Diesel fuel is getting ridiculous.
Old Apr 5, 2004 | 07:53 AM
JKE's Avatar
JKE
From what I have read...(I have no first hand experience)...even larger mesh will begin to reduce the benefit. Like everything else, you can go too far either way. Would be interesting to read what all Car-Nut tested...- JKE
Old Apr 5, 2004 | 11:22 AM
Agades's Avatar
are they gonna make one for a B-1????
Old Apr 6, 2004 | 11:42 AM
Car_nut57's Avatar
Originally posted by AK RAM
Looking at the one I had (sold it), the holes were less than 1/4" in diameter. It just seems like it would be restrictive, to the point of taking away from some of the benefit. Wonder if they made one with hole sizes in the 1/2" range what the results would be. It would definitely let more air through and lend to feeling better about purchasing one. Look'n at it, it blocks a lot of the air way.
The cell size is nominally 1/8" x .8" long. The relationship between cell size and length is important to creating smooth efficient flow. If you use a larger cell the length must also increase proportionally to have the same effect. Among other factors there is not enough space for a longer cell length.
Old Apr 6, 2004 | 11:47 AM
cquestad's Avatar
Will it work "forced in" the rubber elbow like mentioned before by someone with a custom or AFE intake? I am concerned that it may be difficult to position. Is the TAG supposed to sit as close to the turbo as possible?
Thanks!
Old Apr 6, 2004 | 12:13 PM
Car_nut57's Avatar
Cell size
I would be interested in hearing from Car_nut57 on the different sizes of vanes they tried during R&D and their results. Surely they didn't just make the thing as is and said "here ya go." Maybe there is a reason for the vanes being so small. The theory passes the common sense test. If they made one with about 1/2" vanes, I would buy one and "make" it fit my intake tube just to test it.
You are right, I have many proto-type parts in the back that were tested for this application before settling in on the one we use. Several factors are involved here, such as cell size to length to optimize effect without excessive length. Another factor is strength of the part, the air can be traveling at several hundred miles per hour and we wanted the part to be able to withstand just about anything.
Old Apr 6, 2004 | 12:15 PM
Car_nut57's Avatar
Originally posted by BigBlue
Do they make one for us 2nd gen guys?
Yes, we have the TAG for the 2nd gen trucks and are working on developing a TAG-II for the second gen trucks as well. You can see more info about the TAG here http://www.dieselpowerproducts.com/tag
Old Apr 6, 2004 | 12:28 PM
Car_nut57's Avatar
B-1 TAG
Yes, we have made the TAG to fit int he B1, however the intake housing needs to be machined and we recommend the silencer ring be installed.
Old Apr 6, 2004 | 12:34 PM
Car_nut57's Avatar
TAG with Torque Tube
Thanks!
We have had some customers install the TAG with the Torque Tube. It is a force fit and I do not care for it as the positioning of the TAG is difficult and no positive location. So it can be done and the TAG does protrude into the turbo a little, but I really don't like the install.
Old Apr 6, 2004 | 12:37 PM
cquestad's Avatar
Well Car_nut57...
Is there a solution that you like better for those with intakes that want to use a TAG?
Old Apr 6, 2004 | 01:59 PM
Car_nut57's Avatar
cquestad,
I think the best way to address the TAG with air intake tubes would be to get aFe for example to have the similar shelf or ridge molded directly into the rubber elbow. I have tried to contact them several times now about this, but no response.
