Tailgate shocks
Old Mar 10, 2008 | 09:21 PM
tristan21's Avatar
Tailgate shocks
Where can I get the assist shocks for the tailgate so it will drop without the slam.
My wifey is a little wimpy and says its too heavy. I suppose if I didnt make her load a 40lb bag of dog food and 6 bags of 40lb water softener salt she would have the strength to lift the gate back up.
As some relationship gurus put it "the weaker sex".
Old Mar 10, 2008 | 09:29 PM
Jason A's Avatar
Take a look at these two, I went with the EZ down.
Works good but sometimes the tailgate support cord? comes out between the gate and the tail light. (heard a crack once but no damage).
http://www.genosgarage.com/prodinfo.asp?number=EZ_DOWN
http://www.genosgarage.com/prodinfo....mber=GATEGLIDE
I bought both, wasnt sure which one I'd like. I still have the Gateglide in the garage (new) for sale........
Old Mar 10, 2008 | 09:55 PM
tristan21's Avatar
I can see why you used the easy down. I might try that one. Thanks for the info.
Old Mar 11, 2008 | 07:08 AM
MikeyB's Avatar
Also have the EZ down. I don't have an issue with the support strap but I had to 'fine tune' the foam rubber piece so it wouldn't bind with the shock when the tailgate is closed.
MikeyB
Old Mar 11, 2008 | 08:48 AM
AkitaSumo's Avatar
That is the key MikeyB...
Old Mar 11, 2008 | 09:22 AM
enafzige's Avatar
I think this is the best thing going for tailgate savers...
http://www.truckspecialties.com/easylift.htm
It's out of the way, and no gas shocks to wear out. The price is good too!
--Eric
Old Mar 11, 2008 | 12:25 PM
XLR8R's Avatar
MikeyB
Hey Mike, I thought your EZ Down was pretty cool when I saw it at HRP last year... but I can't remember if you had it just on 1 side or a pair? Are the kit prices in the links above per pair or for each side?
Old Mar 11, 2008 | 12:49 PM
jrussell's Avatar
Originally Posted by tristan21
...she would have the strength to lift the gate back up.
Just a FYI...the EZ Down doesn't make it any easier to lift the gate. If anything it makes it a tiny bit harder because you also have to compress the shock as you lift and close it.
It works good, but I've been fighting the strap issue for a while. I've tried to fine tune the foam stopper thing but it will still snag and bind occasionally.
Old Mar 11, 2008 | 03:44 PM
MikeyB's Avatar
Hey Mike,
Only one per kit and it mounts on the driver side. One is all that is needed for the tailgate.
I picked mine up at Camping World when it was on sale for about $45.
MikeyB
Old Mar 11, 2008 | 04:45 PM
Wolfeman's Avatar
I have the easylift that Eric mentioned. It works great, one hand up or down, only about 5 lbs, less than a gallon of milk. A two man job to install but not too difficult.
whosdunit
Jan 11, 2017 01:54 AM
EverydayDiesel
Aug 19, 2007 09:38 AM
Shovelhead
Aug 13, 2005 08:58 PM
BigBlue
Oct 19, 2002 01:07 PM
EricBu12
Oct 6, 2002 03:56 PM
