Symptoms of blown Rail valve...
Old Jan 29, 2009 | 12:01 PM
2007 5.9's Avatar
Question Symptoms of blown Rail valve...
I have been having occasional long crank/hard starting for about a week. Ever since I installed my MP-8 I have had this issue, it doesnt do it all the time but usually first thinhg in the morning or after it has sat for more than 4hours...it takes 4-5sec longer to start and it acts like it wants to in the normal time frame but sputters out and takes a little more.
I have removed the MP-8 and returned my truck back to my original settings...but to no avail. I am wondering if I might have blown my rail valve 2 weeks ago on the dyno. I was running Smarty TNT/R on RP-3 and made a run with the MP-8 on 100%.
What are some ways to test for a blown valve???
I can still make and maintain excellent RP just seems that the system bleeds down over time.
I also have NO rough idle or white smoke...and not making any oil!
Old Jan 29, 2009 | 12:04 PM
MikeyB's Avatar
Remove the return line off of the valve and see if fuel is dribbling out. If so it's bad.
MikeyB
Old Jan 29, 2009 | 12:08 PM
mishkaya's Avatar
If you can still get good rail pressure I doubt it's the valve. In my case at least the truck became very doggish and lots of smoke when the valve went bad.
mishkaya
Old Jan 29, 2009 | 12:43 PM
bradler's Avatar
careful though, i had symptoms of popped valve and pulled the return line to find it full of fuel. ended up being a false positive, had it tested and no leakage at all. guy at the shop said a little fuel can flow backwards through the return line and end up on top of relief valve....
MikeyB
Old Jan 29, 2009 | 12:55 PM
greg_bingham's Avatar
when mine popped, i was going over a set of railroad tracks- felt like i'd pinned the pedal, but hadn't.... I looked back and there was a huge gout of black smoke in the road....
truck ran fine for the 12 miles back to the house. when i went to crank it, i had a long crank, followed by a smoky, not-all-cylinders-fueling-escalating-lumpy rise in engine rpm until i shut her down.
dealer said fuel rail had cracked.
Greg
Old Jan 29, 2009 | 02:08 PM
jlibert's Avatar
you might also consider the possibility of a weak valve. Sometimes they can seal back up, but bleed off pressure at a lower psi.
just block the darn thing off and be done with it.
Old Jan 29, 2009 | 02:26 PM
JOESHTRDDSL's Avatar
I agree!!!! I have had no problem with mine blocked and its been about a year now with no ill effects.
Joe
Old Jan 29, 2009 | 06:11 PM
cquestad's Avatar
MP-8 on 100% with RP3 is no good...plug the valve!
Old Jan 29, 2009 | 06:40 PM
2007 5.9's Avatar
Going to plug it tomorrow...anyone have pics of the process???
Links to pics of the process???
Parts list???
Old Jan 29, 2009 | 07:00 PM
jlibert's Avatar
I'd just call john at floor it and get one of his. It's a nice solid piece, and it's only about 40-50 bucks. That way you don't screw up your stock valve.
Old Jan 29, 2009 | 07:18 PM
mishkaya's Avatar
I agree with jlibert , that's what I did anyway.
mishkaya
Old Jan 30, 2009 | 10:19 AM
cquestad's Avatar
You don't screw up anything...just tap the banjo bolt!
The plug can be removed and all is normal!
Or...you can spend $50. lol
Old Jan 30, 2009 | 10:57 AM
Just tap the banjo bolt and put in a steel plug. It will cost you a dollar and is reversable. That is how I did mine and it works great.
Joe
Old Jan 30, 2009 | 01:21 PM
DUKCALN's Avatar
Parts list???
Less, I too have the same symptoms as you. 4-5 SECOND starts after truck has been sitting for awhile. Started after i installed and used the mp-8. Let me know how it turns out for you. I may try and cap my rail to and see what happens. Lets keep each other informed. I would like to see some pix or a write up on the process.
Old Jan 30, 2009 | 05:22 PM
DUKCALN's Avatar
Wait, I have the dual feed line, I guess that eliminates the valve for me......
