Swapping a 2wd 48re to a 4x4
Old Nov 24, 2008 | 07:33 PM
SmokinDodge12V's Avatar
What all has to be swapped between the two trannys do you have to swap the overdive units and the output shafts or one or the other. Thanks
Old Nov 25, 2008 | 08:18 AM
bigjohn04's Avatar
If I'm right you do have to swap both the 2wd OD section and output shaft out to the 4x4 parts.
What are you trying to do?
Old Nov 25, 2008 | 08:36 AM
Mcmopar's Avatar
That's all you will need to change, you can steal the shaft from a 47RE, and the case too.
LockedandLoaded
Jul 25, 2011 08:14 AM
Rednecktastic
Jun 15, 2010 08:16 AM
V.R.Wheeler
Aug 4, 2007 01:00 PM
