Suspension systems and rear sag
Old Jan 20, 2008 | 12:47 PM
spooling's Avatar
Alright Im lookin at the Carli starter levelling kit, my stock suspension sucks. The only thing holding me back is worrying about rear sag. I often carry pallets of cement in the box and tow heavy goosenecks. Should I look at perhaps adding a block to the rear with the suspension kit? Should I supplement the rear with air bags? I am open to also considering the Lorenz kit.
Old Jan 20, 2008 | 12:51 PM
jkitterman's Avatar
What are your problems with the stock system. It seems very odd you want to jack up the front of the truck about 2 inches to get rid of the built in rake and then worry about rear suspension sag.
Old Jan 20, 2008 | 01:01 PM
alwaysfaded's Avatar
i have carli full leaf springs ,and i tow 15000lb toy hauler. i load my truck pretty heavy with tools and lumber, and it does sag down but not as much as stock. i will be going with carli airbags, but if you arent using your truck off road you wont really need those just some normal bags will work.
Old Jan 20, 2008 | 01:03 PM
ptgarcia's Avatar
Who cares about sag. Get the Carli setup.
Old Jan 20, 2008 | 01:27 PM
firemansdiesel's Avatar
Doesn't matter what springs you have in the back. Big enough load will make your truck sag. Air bags if you are going to hual/tow heavy to level the truck and get some kind of control and ride comfort.
Old Jan 20, 2008 | 01:51 PM
skynyrd's Avatar
i put 2" blocks in the rear so i could keep the rake look and put a set of timbern load bushings in the rear i like them alot they don't effect the stock suspension any and are only in use when the weight in the bed causes the rear to sag 1/2 inch and then it stops.
Old Jan 20, 2008 | 04:38 PM
spooling's Avatar
Stock system rides rough and I can tell I need new shocks anyways
how much for the carli airbags, compared to other airbags?
Sag looks terrible and I think I run the risk of getting pulled over by dot. Not something I'm interested in
Old Jan 20, 2008 | 04:49 PM
NB64's Avatar
Airbags with an on board air compressor will make a big difference. When the rear starts to sag under a load just add air until level. Once load is off just deflat the bags. Works great when towing a fifth too. Sometimes just adding a pound or two makes a world of difference in handling...
Old Jan 20, 2008 | 10:41 PM
spooling's Avatar
So will any airbag setup work with the carli system? What are some recommended air bag/compressor systems. How much for the typical setup?
Old Jan 21, 2008 | 11:14 AM
CrazyFloyd's Avatar
I did not want to spend the money on air bags so I bought an add-a-leaf for 85.00; took one of the 1 inch blocks installed and replaced it with the add-a-leaf. Truck sits level with the 110 gallon tank full and squats just a little when a haul the gooseneck with about 15K on it.
Old Jan 21, 2008 | 02:04 PM
carli bags are about $900 plus full leaves are around $1200 but the ride you get is priceless
on a side note fireman we should get together im in the 707 also towards occidental look me up
Old Jan 21, 2008 | 03:59 PM
ptgarcia's Avatar
If you're going to add the typical air bag setup or add-a-leaf don't waste your money on a better suspension. Adding that stuff will just wipe out the better ride of the suspension system.
Old Jan 21, 2008 | 04:17 PM
cquestad's Avatar
ptgarcia....phhhttttt!
IF special attention and a few custom parts are made...you can utilize an off the self air bag kit and not compromise a "performance suspension" too much.
I did...
But...I still wish I had a few extra bucks laying around for a Carli Air Bag kit.
Old Jan 21, 2008 | 05:53 PM
That's funny, I am also 707 in Bodega Bay.
Sorry to hijack the thread. My answer is in the above post.
Old Jan 21, 2008 | 06:15 PM
ptgarcia's Avatar
I did...
Bags just limit travel too much. I'd like to make more travel, not less.
