Superchip and egt's
Old Mar 2, 2010 | 08:12 PM
John Beere's Avatar
Superchip and egt's
With my superchip i'm running 1400 degrees and 43psi at 3/4 throttle, when i mat the go peddle the wastegate opens, drops the boost to 25psi and the pyro pegs. Would a boost fooler help with the egt's?
Old Mar 4, 2010 | 04:35 PM
LReiff's Avatar
Sounds like your waste gate is hung open...
Old Mar 5, 2010 | 08:20 PM
John Beere's Avatar
If the wastegate was stuck open i wouldn't make that much boost. I'm just thinking if the wastegate stayed closed i would stay around that 1400 degree mark. I'm getting close to boost pressures that would require head studs and hoping the boost fooler wouldn't push me over that line.
Old Mar 6, 2010 | 03:34 PM
Silverram03's Avatar
What kind of turbo? If its stock your on borrowed time with that much boost.
Old Mar 7, 2010 | 12:17 PM
John Beere's Avatar
it's the stock turbo.
R.T.D.H.S.P.
Jun 21, 2007 09:05 AM
DieselNoob
Apr 19, 2007 08:27 PM
garybg1
Jan 16, 2007 08:46 AM
cyclopshotrod
Mar 21, 2005 12:43 PM
