Super B on stock engine??
Old Oct 8, 2008 | 09:21 PM
stock03's Avatar
Originally Posted by DUKCALN
your pretty close to max, add a boostfooler and lose the cat and your golden
I'll PM you. I don't want to hyjack this thread. Thanks for the info though.
Old Oct 9, 2008 | 03:13 AM
DutchYellowRam's Avatar
Originally Posted by jgiachino
Get as soon as you have a programmer:
EGT Guage - so you can ensure you're not melting your motor with the programmer set too high
Boost Guage - So you can read all that boost your getting from the turbo(s)
Trans Temp Guage for the Auto (esp if you tow a lot or if live in a hot area)
I have these 3 gauges allready.
I will try to get rid of the Six Gun and buy another programmer
Witch air intake/torqeu converter I should go for?
For de intercooler I've heard BD and spearco are good.
And for the injectors i've heard DDP's. witch type? Are there more options?
Where can I buy all thse parts? End how much would it cost?
Are there other think inside the engine(like bearings or somethink) That need to be stronger?
Because I proberbly need to take my engine out of the truck. So now is the perfect time for that
Old Oct 9, 2008 | 11:58 AM
DUKCALN's Avatar
Call BD, run there TQ, COOLER X-tuner. THey shoiuld give you a good deal. Talk to Pat.
Old Oct 9, 2008 | 01:19 PM
soulezoo's Avatar
DTR 1st Sergeant
I beat your brothers car at the track...
Old Oct 9, 2008 | 04:11 PM
stock03's Avatar
Huh? I don't think he's ever raced it. Not even a street race.
However, if you meant your truck has a faster time then a 2007 GT, then it went "over my head" , and now I get it.
Old Oct 9, 2008 | 04:58 PM
COUNTRYBOY's Avatar
2003 HO's had cats? all you need is a SMARTY and THEN YOUR GOLDEN even just a SMARTY Jr. Right now all I run is my smarty and my turbo's way bigger and it spools good. Sorry didn't mean to high jack the thread...
Old Oct 9, 2008 | 05:33 PM
Big Blue24's Avatar
Stock bearings, rods, etc are great up to 800 rear wheel hp. Above that level, you run the risk of breaking the bottom end but still not really that many breaking lots of stock bottom end parts till 1K rear wheel HP or so.
Basically, 99% of guys don't need to touch anything in the bottom end.
Old Oct 9, 2008 | 05:49 PM
stock03's Avatar
No cats on 03 or early 04. 04 1/2 is when they started, I think
Old Oct 9, 2008 | 06:06 PM
05CTDN8's Avatar
^^^true^^^
Old Oct 11, 2008 | 03:43 AM
What type injectors should I run? 65HP or 90HP or is that to much?
I see prices of 600 or 800 dollars. Is that 1 injector or all 6 injectors?
What brand and type Cold Air Intake should I go for?
Old Oct 12, 2008 | 02:08 AM
Big Blue24's Avatar
Whole injectors will cost 6-800 a piece at least, just the upgraded nozzles that you install in place of your stock nozzles will be 600-800 for all 6. If you want your injectors to be repaired and then properly setup and tested with high performance nozzles, you could pay around 12-1400.
SlingShot
Apr 4, 2011 08:05 PM
Diesel Dave2
16
Dec 20, 2008 07:11 PM
Buckshotmckee
Apr 19, 2005 07:20 PM
MonroeDiesel
15
Mar 25, 2005 12:54 PM
