Subwoofers
Subwoofers
I have decided that the infinity system in my truck just isn't cutting it and I am planing on upgrading. My first question is, has anyone used a MTX Thunderform sub box, if so how does it sound? And second, does anyone know off the top of their head what size the speakers are in the front and rear doors, I only wish to dismantle them once. Thanks for any input.
I'm using the Q-Logic box which has room for a single 10" which so far has been plenty. I use a 10 Infinity aluminum cone(forgot the model name) and the subwoofer if great, but the box really needs a little thicker baffle baord or more reinforcement as it tens to trasmit the excess energy through the baffle due to it not being stout enough. I'll figure something out.
I use 6.5" CTD(yellow ones...the best speaker) in the front, and 5.5" CTD(red ones) inthe rear along with an Audison 5 channel amp.
All of this is amazing sound, but the week link is the Q-Logic box. Don't know about the one you mentioned, but I had considered it too and decided that one GOOD 10" would be more than enough bass for a Ram QC.
Next, I will spring for the $400 or so to have a custom fiberglass box built.
Good luck.
Good luck.
I know that JL audio also makes a custom box.
furthermore, put 6.5's up front and 5.25's in the rear. I don't know who thinks there 6.5's in the rear but that's no good.
IMO, two subs sound better than one. or, two subs with moderate power sounds better than one sub with gobs of power.
you will, however, have to remove the metal floor system...booo.
I'm gettting a system put in tomorrow morning and having them run the rca cable back there if I want a sub, but holding off the see if it's worth the money and loss of metal racks.
scott
scott
not sure on the infinity system trucks but 6.5 in the rear doors and 6x9's in the fronts, no issues Alpine pushes them well and I am looking for a box for tens as well, gotta buy me somethin w/ my Christmas bonus
Originally Posted by lucey
I have some pics of the system i built in my gallery. I have 2 JL 10's with a 500/1 and a 300/4 powering a set of Diamond 6.5 mids and tweets. Enjoy !
I've got a JL 10W6 in the center seat and plan to add the other one under drivers side rear seat...I do wonder if my 500/1 will power both well enough?
JL 5-1/4" in the rear doors and MB Quart 6.5's in the front
The fills are running off of two MTX amps.
Scotty
Scotty
I have pix somewhere but its quite simple. The bottom of the center seat is now a sub box and the console/armrest is attached to it. I also had a slot built in the front of it for the CB...I had a heck of a time trying to find a spot for the Cobra radio and this worked out good. I may put a cover on it at some point.
I wanted my rear fold flat floor intact so I went this route. I now see that I can make my own enclosure for a single sub and Maybe...just maybe keep that fold flat side. Sure hope so but its not a big deal to lose the smaller portion of that feature.
The center seat sub sounds REAL good and I agree with others...having two subs is better. I am told the 500/1 will run the two dual voice coil subs, I guess I need to find out for myself. The center seat sub fires down at the floor.
Scotty
Scotty
sounds pretty slick. if you can I'd love to see some detailed pictures of that setup. good idea putting the cb on the front of the box.
if you do take pictures I would really like to see how the center console is attached to the sub.
I will be digging through some pix over the holidays and will post asap.
Scotty
p.s. the center seat is no longer a seat in this configuration.
Here is my dillema.
I have a kenwood dvd player in dash, and its processing unit in the comparment under the center seat. I am looking to get a subwoofer, and a nice set of 6.5" and 5.25" component speakers for the rear. I am leaning towards the JL stealth single 10". Its expensive, but I've had good luck with their stuff in the past.
I am hoping to be able to mount one amp under the pass. seat, and one under that processing unit under the middle seat (that plastic cup was cut out, so there is plenty of cooling), I'll be able to still use the 60% of my rear floor space, while the 40% hides the sub underneith... I hope this can work for me.
I fit 1 amp for the mids and highs along with my dvd processor under my passenger seat and fit 1 amp for the subs along with a stiffing cap under the drivers seat. I'll try to take some pics and put them in my gallery.
itsallgood
itsallgood
