Stock Injectors vs Aftermarket (attn: DonM)
Old Jan 19, 2007 | 08:25 AM
HappyGA's Avatar
I am considering injectors, and I know these trucks love it when a downloader and a pressure box is combined. From reading here, stock injectors do not like additional pressure added.
question #1: Do the stock injectors not like the added pressure because of the inadequate filtering of the 10 and 7 micron filters? Doe sthe small particles that are not removed do most of the damage? So what if we installed a 2 micron filtering kit? I know this will give you better filtering and will remove a lot more of the harsh stuff, but would it actually make stock injectors live longer?
question #2: Are aftermarket injectors as vulnerable to pressure boxes as stock injectors?
What injectors are reccommended with a SMARTY and lets say an MP-8 stack??
Old Jan 19, 2007 | 09:13 AM
Cowboy 6's Avatar
Very good questions. I was on the phone with DDP and F1 but I do not feel comfortable quoting the conversations. But from what I understand is that it is the injector body that causes the issue. I would recommend that you call these folks and hear the info first hand.
Old Jan 19, 2007 | 09:20 AM
Silver76's Avatar
I believe that the pressure itself cracks the stock injector bodies- not necessarily any contaminants. So 2 micron filtering will not help failure due to pressure.
Don advertises that his Flux 1 injectors are good to go with pressure boxes.
You need to ask Don about what he reccomends if you're planning on running a modded cp3 and a pressure box. I think that the combo creates too much pressure.
Someone chime in if I'm wrong...
Old Jan 19, 2007 | 10:44 AM
cquestad's Avatar
Get a rail gauge and keep it to 25-26 ksi max...no matter the combo!
Old Jan 19, 2007 | 11:15 AM
stang's Avatar
I think the pressure with the dirt cracks the bodys. Trys to blow the dirt thru the tip wont go something has to give at high pressue. Yes you do need 2 micro filter when running pressure. better safe then sorry.
Old Jan 19, 2007 | 11:28 AM
GEN3TRQMONSTER's Avatar
Where can I purchase a set of Flux 1 injectors?
Old Jan 19, 2007 | 12:25 PM
HappyGA's Avatar
so our stock injectors can withstand this amount of pressure?? Isn't stock pressures somewhere around 19-20,000 ksi???? ksi??? what is that measuring??? do you have a conversion fctor to psi?? Thanks again C...
Old Jan 19, 2007 | 12:29 PM
ptgarcia's Avatar
ksi = 1000 psi
k stands for kip, which is 1000 lbs.
So saying 20,000 ksi is the same as 20,000,000 psi. 20 ksi is 20,000 psi.
Old Jan 19, 2007 | 12:39 PM
HappyGA's Avatar
oh okay, got yah. thanks for the clarification...
Old Jan 19, 2007 | 01:25 PM
cquestad's Avatar
Sorry I was being a engineering nerd...
Pauly explained it perfectly....
I could have been worse and said keep your rail at 3,600,000 - 3,744,000 psf.
Old Jan 19, 2007 | 01:44 PM
wap's Avatar
wap
To answer about factory rp, mine has spiked over 25k befor with no added pressure. Not very likely to happen and if it does, its not often but it can happen.
Old Jan 19, 2007 | 02:15 PM
HappyGA's Avatar
well, i guess a rail pressure gauge will be on my mod list now..
Still would like to hear from the injector designers of what they think the most common cause is, and what kind of modifications can we do as individuals to help pro-long our stock parts or even some of yalls after market parts..
Old Jan 19, 2007 | 02:33 PM
Cowboy 6's Avatar
I was told by DDP that I should absolutely add one of these to my truck to protect the injectors.
http://www.glacierdieselpower.com/pr...?pf_id=MK20306
Old Jan 19, 2007 | 02:51 PM
HappyGA's Avatar
I have the walbro 392, I wonder if I could mount that on the frame between fuel tank and the walbro??
Old Jan 19, 2007 | 03:20 PM
tcr's Avatar
tcr
If you have a bracket, or you can mount the filter head to a 4" square area on your drivers side floorboard, between the frame rail and the front drive shaft. Just pull the insulation below back and pull your carpet back and you'll see where I'm talking about. It will take 4- 1 1/2" x 3/8" bolts.
