Stock injectors/CP3 enough?
Old Jul 29, 2007 | 06:04 PM
$oC@l CTD's Avatar
Let's say that I was going to tow approx 10-14K, turn the Puck on the low setting (60hp) and the Edge on level 2, do you think that the stock fuel system would spool a HTT Silver 62/13 to keep my EGTs down in the mountains? Let's hear it gurus!
Old Jul 29, 2007 | 08:39 PM
$oC@l CTD's Avatar
Nobody out there running a similar setup to this with some input?
Old Jul 29, 2007 | 09:22 PM
turbopwr's Avatar
A buddy of mine just put a 62/12 on a guys truck, stock one went bad. said it was a tad laggy stock but it did run better when got above 2000rpms, with stock fueling. Put a 65hp quad on it and it does fine ,runs a pulls good.
Old Jul 29, 2007 | 09:23 PM
trik396's Avatar
If you weren't towing, I'd say yes, but you are...I wish I could help you but I don't tow.
Stock injectors and cp3 ought to be enough but do you have a better fuel pump than stock?
Old Jul 29, 2007 | 09:43 PM
triplenickel's Avatar
Try this one;
https://www.dieseltruckresource.com/...d.php?t=154128
Old Jul 29, 2007 | 09:50 PM
$oC@l CTD's Avatar
Seems like with a little timing/duration provided from my Edge and a pressure box like my Puck, I will be lookin pretty good for spooling it...that's great! I need to keep these EGTs in check. Trik396, I am still on the stock lift pump, but I can get one at some point...they aren't that expensive...
Old Jul 29, 2007 | 11:28 PM
morkable's Avatar
You wont have any problems spooling that turbo,, but egt's could be an issue... just have to watch it and see
Kevin
Old Jul 29, 2007 | 11:49 PM
$oC@l CTD's Avatar
Kevin
So you're saying that I might go from slightly higher egts (approx 1250-1400 while towing 10K on grades) with Puck off and Edge on 1 to slightly higher EGTs (about the same) with upgraded fuel and a Silver 62? Why even waste the money when I can just turn things down and slow down?
Old Jul 29, 2007 | 11:54 PM
morkable's Avatar
That is a tough question, as to how much egt's would drop. But you should be ok with what you have, you will just have to pay attention closely
Kevin
Old Jul 30, 2007 | 12:09 AM
$oC@l CTD's Avatar
Kevin
This is the kind of stuff that I like to hear and one of the MAIN reasons that I came aboard this forum...there are SO many people that just run out and blindly buy something without asking questions from the people that actually KNOW first hand (such as a dealer who WANTS you to spend your money) and find out the hard way that they wasted their money. I appreciate it Kevin...that's a couple thousand that can stay in my pocket...at least for the time being
Old Jul 30, 2007 | 01:03 AM
morkable's Avatar
No problem,, just make sure that you keep an eye on it, and you should be ok
KEvin
Old Jul 30, 2007 | 04:21 AM
Dodgezilla's Avatar
With my current stack my temps stay nice and cool, even towing. But I haven't towed with the Predator higher than the Tow setting. Guys with similar mods to mine minus the 62/12 turbo are seeing EGTs of about 2-300 degrees higher. I would say my turbo is working for me.......
I still hold good fuel pressure too, even while towing...
Old Jul 30, 2007 | 08:48 AM
$oC@l CTD's Avatar
So your 62/12 lowered your temps by 2-300 degrees? That is pretty substantial...cheaper than the Silver 62/13 too...hmmm
Old Jul 30, 2007 | 11:27 AM
TX_Diesel's Avatar
Only cause i'm curious. The above quote raises a question for. Why did you buy a 4" exhaust when your turck came from the factory with SS 4" exhaust?
Old Jul 30, 2007 | 04:46 PM
$oC@l CTD's Avatar
1.) It is T-304 Stainless steel rather than aluminum.
2.) It looks MUCH better
3.) It sounds better than stock with just a muffler
and the fourth reason, I will just not mention since it's "against the rules"...but it's TURBO back...that's your only hint...
