stg 2 Floor it CP3
Old Mar 20, 2007 | 05:59 AM
dodgeboy59td's Avatar
stg 2 Floor it CP3
What will this do to my current setup? (crazy (scary larry) PMCR and Edge EZ) Whats the expected hp increase? Wes
or should i go with some injectors?
Old Mar 20, 2007 | 06:19 AM
lmills's Avatar
With that stack you are most likely on the verge of draining the rail. A set of injectors will without a doubt push you over the limit. The stage 2 is probably your best bet. It will broaden your power band and raise the power curve a good bit. HP numbers are hard to guess, it all depens on how much you are currently draining the rail.
Old Mar 20, 2007 | 08:05 AM
omaharam's Avatar
Not sure if he's ready to start sellig them yet, but call John and ask about his new stage 1. I'm bettin' it wil take care of you and save you some $.
Old Mar 20, 2007 | 09:46 AM
973604x4's Avatar
Scary Larry doesn't do any more than Crazy Larry on 06's, we tried sunday. If you had the real Scary Larry, you wouldn't want to stack any timing device on top of it......although it has been done. Timing rattle is very bad on my truck til it gets TOTALLY warm, until then its noisy. Thats with the program installed and nothing else on the truck but a boost fooler.
Old Mar 20, 2007 | 09:51 AM
Bob Wagner's Avatar
stage 2 have been selling for months the stage 3's are on deck
Old Mar 20, 2007 | 10:18 AM
Sloverado's Avatar
I have had great luck with my Floor It pump. You will see what your truck can really do when you get a modded cp3. Most big tuners you can see the potential as the stock pump can't keep up.
Old Mar 20, 2007 | 10:34 AM
lcaad1249's Avatar
With the exception of my Smarty we've got a similar stack. I just installed John's Stage 2 on Sunday. All I can say is Oh my God. This thing is making an insane power difference. Not sure about overall HP increase but it comes on so much quicker. I almost wiped out my truck on the first intersection I turned on not even on it very hard. I highly recomend it.
Old Mar 20, 2007 | 01:26 PM
acook's Avatar
Looks like i wont be updating to the crazy larry...they said it would add power but i guess not.
Old Mar 20, 2007 | 01:34 PM
973604x4's Avatar
check PM's here shortly.
Old Mar 20, 2007 | 08:12 PM
jvjump's Avatar
I am also running out of fuel i will try to get a mod cp3 by april 28. We are having a dyno that day at a friends house. I will try to run the truck before and after with a mod pump. If i can come up with the cash for the pump. Consider it done.
Old Mar 20, 2007 | 10:24 PM
94ttss's Avatar
Give John at Floor It a call. I put his Stage 2 on over the weekend and all I can say is WOW! The power comes on so hard down low and doesn't let up till I take my foot out of it. Night and day difference. I can only imagine what his Stage 3 is like .
TrkEnvy
Jun 7, 2009 01:13 PM
tristan21
23
Mar 10, 2008 12:50 AM
JD Dearden
50
Aug 20, 2007 09:59 PM
WideOpenThrottl
Mar 29, 2006 07:28 PM
Abbynormal
21
Mar 15, 2006 05:15 PM
