Stacks, could it really be this easy?
Old Dec 11, 2008 | 01:32 PM
buddy26's Avatar
I just crawled under my truck and it looks like all I have to do is cut my exhuast pipe, put on a 90, cut a hole in the bed and insert stack. Is it that easy? Also Ive removed the kitty and tried the truck straight piped= way to loud, so I found a magna flow diesel muffler and now want somthing a little louder. what muffler would you guys recomend?
Old Dec 11, 2008 | 01:37 PM
HOBrian's Avatar
If you want just one stack... then yes it is that easy!
Old Dec 11, 2008 | 01:42 PM
na4now's Avatar
Yes, running a single stack, can be that easy.
Old Dec 11, 2008 | 01:49 PM
Kenny D's Avatar
just remember to put somthing in there to flex saw one guy mount evrything solid the bed didnt do so well
Old Dec 11, 2008 | 01:51 PM
rip 112's Avatar
If you're gonna do a stack keep the muffler you have for now because the truck will be louder and the noise will be right outside your back window.
Old Dec 11, 2008 | 03:22 PM
buddy26's Avatar
where can i buy a slip on 90 w a 4" id?
Old Dec 11, 2008 | 03:39 PM
Jason_K's Avatar
here's a good site
http://store.airflo.com/exhaust-elbows.html
Old Dec 11, 2008 | 03:53 PM
choupique108's Avatar
i have a magnaflow muffler with a set of 6" mitors and I love it
Old Dec 11, 2008 | 04:09 PM
na4now's Avatar
Find a big truck parts supply store. They have several around where I live. They have everything.
Old Dec 11, 2008 | 05:27 PM
cdennyb's Avatar
From: In Oroville, Ca., same house for past 46 yrs!
or... just find some stainless and run 4 in up thru the bed, to a 6 x 6 x 4 tee, and then run a 6" across the bed in each direction from it, then 45 the 4' pieces that you miter cut already and TIG weld everything square... then you'll have something.
Look here... post #4 at: https://www.dieseltruckresource.com/...d.php?t=183244
RamWheelsBy4's Avatar
Yep pretty easy. Few clamps, an adapter or two, 90* elbow, brackets, clamp, hole saw, sawzall, welder, flex tubing, maybe a coupler if needed and of course the stack itself. A little measuring, cutting, welding, hamering, adjusting, cussing and your about done.
Old Dec 11, 2008 | 05:48 PM
Here is what I used for my single 6" miter cut with AeroTurbine 5050XL muffler. Most of the parts came from airflo.com or in the garage.
Old Dec 11, 2008 | 05:49 PM
buddy26's Avatar
Local napa said they had everything but the stack. getting started tomorrow.
Thanks
Old Dec 11, 2008 | 06:01 PM
Mocho's Avatar
If straight piped is to loud how are you going to stand stacks even with a muffler? The exhaust is right behind you, can't see it being to quiet even with a muffler.
Old Dec 11, 2008 | 10:32 PM
Neight's Avatar
I don't want to thread jack but can some of you guys crawl under your trucks and snap some pics so I can see your set ups.
