Stacking Edge EZ? What works??
Old May 30, 2007 | 01:16 PM
pik's Avatar
pik
Has anyone stacked the Edge EZ moduale?
Anyone know what would work with the EZ?
Old May 30, 2007 | 02:32 PM
Gas Sucks's Avatar
Stacks good with just about everything, i have stacked it with Triple Dod and Smarty, worked great
Old May 30, 2007 | 02:36 PM
$oC@l CTD's Avatar
Yeah, Edge EZ is simply a pressure box...so as stated above, it will work with pretty much ANYTHING out there. Edge Juice with Attitude is it's "sister" module...stacked they work well together and you will have on the fly adjustability, be able to monitor a multitude of different parameters, such as boost, EGTs, engine temps, trans temps, slip rate, etc...plus for $100, you can have them program the "Hot" upgrade into the Juice and give you more hp/tq. The options are yours, just shop/ask around...you'll end up happy!
Old May 30, 2007 | 02:37 PM
$oC@l CTD's Avatar
Oops...belay my last...since you already have gauges (I didn't pay attention, sorry) it just opens up your decidions even more. But still don't count the Juice out...you can just order it without the Attitude monitor...
Old May 30, 2007 | 03:47 PM
973604x4's Avatar
Edge Juice, TST, Bullydog, Diablo Predator, Smarty, etc
lots of possible stacks
Old May 30, 2007 | 09:37 PM
RamWheelsBy4's Avatar
Yep what they said. My EZ has been stacked with Juice, Hot Juice, BDTD, Smarty and TST. Has added something positive to every one of those mods.
Old May 30, 2007 | 11:20 PM
RedRacer44's Avatar
Just like what everyone above has stated...the EZ stacks well. I stacked mine with a Triple Dog and a QZilla Boost Fooler....worked very well!
Old May 31, 2007 | 07:30 AM
pik's Avatar
pik
Forgive my ignorance, I am new to the diesel world. Would I have to use something that plugged into the ODB port since my MAP and fuel pressure sensors are already tapped into. How would you stack another unit??
Old May 31, 2007 | 08:24 AM
Normally the only common connection with a Timing/Duration box (TST, Juice, etc) is the MAP sensor. This connection is just piggy backed for that sensor, EZ into MAP, timing/duration box into EZ and factory into timing/duration. The order of connection is subjective and could be different for a particular box.
Downloaders (BD Triple Dog, Smarty, etc.) do use the OBDII/CAN Bus connector to load programs and therefore is no conflict with the EZ connections.
Old May 31, 2007 | 08:57 AM
pik's Avatar
pik
Thanks for the responces.
Old May 31, 2007 | 09:02 AM
Beeram305's Avatar
Don't stack the EZ with the juice on the 03-04 trucks, as both add pressure. You would be fine if it was an 04.5+, but you would be putting injectors at risk with an 03. I would recommend a TST or a smarty, but you would need supporting mods as far as fuel system and trans to get the full benefit.
blue2002
Nov 24, 2010 11:46 AM
toupee
32
May 6, 2007 11:03 PM
hotrod929
Dec 27, 2006 11:10 PM
John_P
24
Jul 13, 2003 08:59 AM
