stacking boxes
Old Oct 15, 2005 | 08:08 AM
catch2otwo's Avatar
stacking boxes
hey guys, im confused about this stacking of different boxes business. i just have no idea how it works. someone shed some light on the idea please
Old Oct 15, 2005 | 12:26 PM
bigman's Avatar
Basically fuel boxes change duration, timing, and or pressure. All three are capable of adding horspower. Some boxes only use for example duration and timing. When you stack a box that advances pressure with a box that does timing and duration it can add more power or change the charactor of the power band. The trick is to find a combo that works. Some stack very well together others do NOT. I tried stacking the BDDL with the edge juice and it wasnt very impressive. Hope this helps.
Old Oct 15, 2005 | 02:34 PM
swansong04's Avatar
does anybody have any experiences with stacking a juice/attitude with a quad xzt 65 hp tow box ??? i have the quad box .. interested in the juice .. thanks for any info
G
Old Oct 15, 2005 | 03:34 PM
RamWheelsBy4's Avatar
I stacked an EZ with the Juice/Attitude. I think the xzt65 is a pressure/boost box and if so should work fine with the standard & HOT Juice/Attitude(timing and duration only).
I also tried the HOT Juice/Attitude with the BDDL Crazy Larry download. The results were ok on Juice Level 1, 2 and 3. Did not have time to really test those combos. Just installed the TST PowerMaxCR and will be stacking first with the EZ and then with the BDDL downloader programs. Then maybe all three.
t-boe
Jan 4, 2007 08:35 AM
rubbert
13
Apr 22, 2004 02:19 PM
Gene007
Oct 27, 2003 03:43 PM
John_P
24
Jul 13, 2003 08:59 AM
