stack install
Old May 26, 2006 | 11:41 PM
sumner's Avatar
stack install
Hey all. I should be getting my stack kit in tomorrow. Im trying to get everything ready to go as far as tools. What size hole did you have to drill in the bed? I have a 5, 5 and a half, and a 6 inch hole saw. I ordered the grand rock 5" kit. Any other info would be greatly appreciated.
Old May 27, 2006 | 12:18 AM
bnold's Avatar
I'm thinking 5.5 then use a cutting tool to make oval if you want it to fit fairly flush with the floor.... Mine is oval
Old May 27, 2006 | 12:25 AM
sumner's Avatar
thanks , i appreciate it. any other tips you can think of off the top of your head? do they give you a template? do you need to cut through the crossmember on the bed?
Old May 27, 2006 | 07:26 AM
B.Law's Avatar
If you want them up against the bed the crossmember will have to be notched unfortunetly. Like bnold said oval works well to snug it to the floor. If you have access to a plasma cutter use it, it will be the easiest.
Old May 27, 2006 | 11:02 AM
Camotanker's Avatar
Yeap... crossmember all to common problem. We went through 2 whole saws and a drill when we did mine. Gots to be an easier way!
Topper
Mar 3, 2008 10:17 AM
white250005
Oct 25, 2007 10:19 PM
smoky beast
Oct 18, 2006 06:58 AM
B.Law
16
Apr 22, 2005 02:28 PM
Cat Cracker
Jul 14, 2003 12:17 PM
