squeal at high rpm's? HELP
Old Jul 12, 2007 | 02:55 PM
35" 05''s Avatar
Exclamation squeal at high rpm's? HELP
Recently I was doing around 70 mph and decided to get on it. @ around 80 I squealed really loud like a belt or something. I have a SBC DD 3600 and that squeaks occasionally when shifting gears for some reason but I hope thats not it. It does it when rpms are kinda high. I know it will be very hard to answer but Im just trying to figure out what it is. The belts don't seem very loose. Kinda like they should feel unless it has to be TIGHT. The clutch was also just put in last year. Thanks for any help.
Old Jul 12, 2007 | 02:57 PM
dodgezilla04's Avatar
high rpm, what was your boost at? the turbo may be rubbing the housing. hopefully not.....
Old Jul 12, 2007 | 04:10 PM
SmokinDodge12V's Avatar
Could be an exhaust leak where the turbo mounts to the manifold Ive had this happen before and it sounded just like a loud squeal.
Old Jul 12, 2007 | 05:31 PM
35" 05''s Avatar
Thanks, I hope thats not it. I was at probably 30 lbs.
89dieselkong
Sep 17, 2011 01:20 PM
NJMurvin
Aug 18, 2010 01:13 PM
skyjumper
May 9, 2009 08:54 PM
Kuntry
Aug 30, 2005 12:57 AM
fishin fever
Feb 22, 2004 08:32 PM
