spare tire mount
Old Feb 26, 2006 | 09:38 PM
lowboy18011's Avatar
spare tire mount
I am running 35 inch tires and want to have full size spare. Are any of you using the tiregate by Wilco? Any other cool spare tire mounts out there?
Old Feb 26, 2006 | 09:46 PM
Nate-03 D's Avatar
I run 35's also and have a full size spare. Tried putting it up under the truck once, was a tight squeeze but I didn't leave it on in fear of the cable not being able to support it. Some good a spare tire is if its sitting in my garage huh?
Old Feb 26, 2006 | 11:11 PM
DirtEater's Avatar
I've had my 35" spare tucked comfortably underneath and the cable is tight as can be...so far. Might not hurt to upgrade the cable to the next larger diameter.
Old Feb 27, 2006 | 07:29 AM
RamWheelsBy4's Avatar
My BFG 315 (34.4") spare is in the stock spare location. Had it there for about a year now with no issues.
Old Feb 27, 2006 | 07:43 AM
Brock's Avatar
I only have 33s but it is up in stock location....if worried about cable then run a small diameter chain through wheel to frame to act as security from theft and backup if the cable fails....but those cables can hold far more than the weight of all 5 tires combined.
If they fail it is usually due to corrosion or abuse....just check it when you change your oil.
Old Feb 27, 2006 | 10:26 PM
Planetcat's Avatar
Ditto here.
J10495T
Sep 21, 2011 04:07 PM
mverps
Mar 13, 2010 09:22 PM
D45
0
Jun 13, 2009 08:43 PM
Boatnik
Nov 6, 2007 07:52 PM
I PASS GAS
May 12, 2006 11:19 PM
