south bend
Old Dec 18, 2006 | 11:15 AM
goodeyesniper75's Avatar
south bend
i just got a new con fe sb clutch put in about 2 weeks ago. i have put about 250miles on it now. it is real grabby...will this lighten up or will it keep doin this cause in rev. it is jumpy and is kind of a pain in the rear.
Old Dec 18, 2006 | 11:20 AM
dodgezilla04's Avatar
she will wear in after a few hundred miles of stop and go driving. until it loosens up, go to 5th gear first, and then to reverse. that should help you(suggested to me by peter of SBC). the grabbiness will get better, though you have an fe, which will be grabbier than an ofe. mine has settled down. my only issue remaining is when starting out in 2nd, with no throttle, the clutch will chatter alittle as i let out the clutch. peter says to give a tad bit of throttle when starting in 2nd, and it has helped.
Old Dec 18, 2006 | 11:47 AM
cool sounds good
biglar
Feb 2, 2003 05:26 PM
AggieJustin
Jan 25, 2003 10:46 PM
29
Jan 21, 2003 10:23 PM
Hired Gun
Dec 18, 2002 02:55 PM
