Sooo Many Turbos, and not enough info.
Old Nov 23, 2008 | 11:55 AM
twoforme2's Avatar
Originally Posted by Joe Reitman
Anyone here ever used a pair of HE351's as a compound setup? Talk about cheap twins... Is this even viable?
If you could split the exhaust and intake into a parallel turbo system, it might work, otherwise, no...not gunna happen
Old Nov 23, 2008 | 03:53 PM
Topper's Avatar
If I were you I would turn things down until you can get up enough coin to keep that 03 cool! They have a real issue with dropping valve seats. Then the valve breaks then that goes into the piston and then the piston drives the broken pieces into the head and then what ever is left goes into the turbo... Then you spend ALOT of money!!! If ya need I can post pics...
good luck and keep her cool.
Topper
hotrod929
18
Apr 17, 2010 10:57 AM
newconcorddodge
Oct 6, 2008 09:05 PM
dditt0635004x4
13
Feb 7, 2007 12:36 PM
1320
30
May 31, 2003 01:01 AM
