smarty stack question....
Old Oct 2, 2009 | 02:55 PM
Jordan5687's Avatar
Question smarty stack question....
Ok, I don't currently have a smarty, but will next summer, I ran across a really good deal with a quadzilla xzt, I'm wondering if I can stack it with the smarty, any way possible?? I'm gonna give the truck a test drive tonight with the xzt before I buy, if I decide to. Any help will be great! Thanks!!!
Old Oct 2, 2009 | 04:11 PM
tantruck's Avatar
Which Smarty ?????? Just a word of caution.
Don't use the Smarty levels, (1,3,5,7,9) that have timing advancement with boxes that also add more timing or you may melt your pistons. Remember the Smarty S06 POD with Revo software is adjustable and can add timing, increase rail pressure, limit torque management and avoid shift defueling.
That being said, I don't use my Edge Hot Juice when the Smarty is loaded but I do like to add a bit of rail pressure increase with my Edge EZ's three postion in cab switch. It livens up the party a bit.
Old Oct 6, 2009 | 11:24 AM
2003Ram's Avatar
What he said ^^^^^
I run the Quad x2 with my smarty, but I had Quad remove the timing. It's a great stack.
Old Oct 6, 2009 | 01:01 PM
Diesel87's Avatar
I am planning on running a MP8 with my smarty. Do I still have to worry about the odd numbers. I am not sure what the MP8 does. Does it raise rail pressure or add timing or both. Since the POD has been out I have been wondering about the added timing. I didn't know at what number it would start adding timing. I like how you can adjust the POD on the fly, but I think the 99 power levels is stupid. I don't need that many options. I'm a simple guy.
Old Oct 6, 2009 | 03:12 PM
cincydiesel's Avatar
You can also eliminate the timing on the Smarty and use timing from the Edge
Topper
Mar 3, 2008 10:17 AM
white250005
Oct 25, 2007 10:19 PM
smoky beast
Oct 18, 2006 06:58 AM
B.Law
16
Apr 22, 2005 02:28 PM
Cat Cracker
Jul 14, 2003 12:17 PM
